Posts: 98 |
did anyone else find installing these an absolute PITA?
i wish i wouldve had the mechanic at work do it for me.
it was alot more time consuming than i read from other peoples experiences, and installing the oil pressure sending unit took FOREVER.
all in all, i cant complain bc it looks great and was well worth it.
2000 SVT Contour. Black. #1889 of 2150.
Posts: 7,025 |
i didnt think it was that hard. Hardest part was fitting the gauges in the pod. I had to actually sand the openings a bit to get them to fit.
Where did you tap the oil pressure gauge?
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 835 |
did mine a week ago and wasnt too hard to install just the pod and gauges but didnt install the wiring yet until the days are longer in the spring or early summer.
-dan
98 CSVT 484/6535,18" MI Rims,Nitto NEO GEN Tires,Pioneer DEH-P7300,Custom Cougar CIA,CF Hood,McCULLOCH HID 6K,Custom painted red calipers,Flowmaster 40s mufflers,Drilled Slot rotors,K&N 9" air filter,Brullen HiFlo Y Pipe & CAT,Magnaflow Res
Posts: 5,600 |
i didnt really think it was hard, but it is a pain in the A. this is mainly cause i HATE wiring. you can find my troubles in a thread or two i started about the oil pressure gauge.
Black 1998.5 CSVT
Posts: 6,791 |
I've installed volts and A/F but haven't got around to the oil pressure yet... I'm waiting for a warm day. The oil is really the only PITA... Otherwise i found it pretty easy... Oh and no need for a mechanic on this
Posts: 98 |
Originally posted by RawBurt: I've installed volts and A/F but haven't got around to the oil pressure yet... I'm waiting for a warm day. The oil is really the only PITA... Otherwise i found it pretty easy... Oh and no need for a mechanic on this
i realize there was no need for a mechanic, but the oil pressure really was a pain. i tapped in down by the a/c compressor.
like i said it was a pita, but well worth it.
Posts: 5,810 |
You should have tapped in on the rear of the cylinder head, same place we tap for the oil supply to the turbos. It also gives a good indication of oil supply pressure to the heads.
See My Mods
Posts: 98 |
Originally posted by warmonger: You should have tapped in on the rear of the cylinder head, same place we tap for the oil supply to the turbos. It also gives a good indication of oil supply pressure to the heads.
yeah, i was going to do that, but i heard doing it on the bottom gives a quicker reading. quicker as far as if i were to lose all oil pressure i would know right away, whereas if you do it on top it takes longer to read that.
