#12726 04/26/02 10:13 PM
I did a search on this board for my answer, but couldn't find it.
I just bought a 1999 Mystique LS (V6) and wish to learn more about it.
What are these "secondaries" people keep mentioning?
#12727 04/27/02 01:31 AM
H
H
Try search again as follows:
secondaries/problem forum/subject only
You should get about 15 hits of prior posts.
stock CD on LS, cass on LX
4 wheel discs on LX only
#12728 04/27/02 01:32 AM
The intake manifold has a dual intake runner setup, versus a single intake runner setup like most other engines have. The "secondaries" are referred to as the second set of intake runners that are opened up by the IMRC (Intake Manifold Runner Control) at around 3200RPM at WOT (Wide Open Throttle) or 3900RPM at partial throttle. The intake runners are what provide air to the cylinder combustion chamber. The "secondaries" are a shorter and larger diameter set of intake runners designed to provide a faster and larger charge of air into the combustion chamber at higher RPM's (versus the intake runners that are always open at low RPM - which are smaller diameter and longer for smoother airflow). In short, it's why you feel that whoosh of power after 4k RPM in the Duratec powered cars... smile
Hope this helps...
Regards,
Craig J. Baldwin
99 SVT Contour - Silver - #49/2760
"To make a living is to get, to make a life is to give." - Winston Churchill
#12729 04/27/02 01:36 AM
If you would a visual aid here is a link to some pictures I took.
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=40;t=002020
-Colter
My Car
#12730 04/27/02 05:29 AM
Thanks everybody!
#12731 04/27/02 06:04 AM
Secondaries are non primaries. laugh
Howard
1998 Silverfrost SVT #1612
June mods:
17" ADR RS Limited Limix Wheels
with 215/45/17 Yokohama AVS Sports
#12732 04/27/02 07:13 AM
H
H
those pics look strangly familiar~~
'98 SVT #2253
Currently DEAD!
Cobra Paradise
