Posts: 494 |
Here's the deal, About once a week or so, when I turn on the factory radio/cd player, the dissplay goes to AM and I lose all my audio settings. I don't lose my radio pre-set channels though! Any ideas? Thanks in advance. Stephen
96 Contour, GL, Zetec, ATX. 03/18/1996 Build Date. Drop in K&N NGK Laser Platinum Premium Spark plugs Niehoff Premium Ignition wires Wheel Well Air Intake Resonator removed. *Just the beginning*
Posts: 4,899 |
Ugh this happened to me before. The factory players suck, they do not seal well against moisture. It is quite pricey to replace, so I recommend getting an aftermarket one instead.
Posts: 494 |
Originally posted by TheGSRGuy: Ugh this happened to me before. The factory players suck, they do not seal well against moisture. It is quite pricey to replace, so I recommend getting an aftermarket one instead. Do the stock stereo systems come with a small battery to keep the memory or is is wired to the car to keep the memory? Maybe a capacitor? Just thought the memory may get lost if backup is weak! Stephen
Posts: 4,899 |
There is a keep-alive memory but I doubt that is failing. What you're describing are early signs of HU failure.
Posts: 494 |
Originally posted by TheGSRGuy: There is a keep-alive memory but I doubt that is failing. What you're describing are early signs of HU failure. Ok what is "HU"? I do have an old kenwood system with 25w/channel that I may have to see if it still works! Thanks for your help, Stephen
Posts: 242 |
hey stephen you should your self a new HU. I work at futureshop and would be glady give you a good deal, and would install it for you too!
1997 T-Red Contour V-6 MTX Magnaflow custom dual exhuast SC Cold Air induction Sony LCD screen with PS 1 Neon interior lights,gauges Momo shifter knob SVT E0 Rims Touring Spoiler In the means to change the sound system.
Posts: 494 |
Originally posted by TrUjAp: hey stephen you should your self a new HU. I work at futureshop and would be glady give you a good deal, and would install it for you too! First off, what is "HU"? Thanks, Stephen
Posts: 97 |
Stephen "HU" = Head Unit Like everyone else already pointed out, looks like you'll need a new head unit.
1998 Contour SVT H&R, Koni's, 17" Team Dynamics DTM Upgraded Stereo System My 98\' SVT
Posts: 494 |
Like everyone else already pointed out, looks like you'll need a new head unit.Ok, thanks. I will replace the stereo when it stops working all together or really pi$$es me off! Stephen
