Posts: 108 |
I am upgrading my entire system. I was wondering what is the maximum wattage that the factory speaker wire can handle? I was thinking of using that wire instead of replacing it all. The output of the AMP is 4X200 watts.
1996 V6 se mtx KKM Intake Superchip Dual Exhaust SVT Flywheel BAT Intake Pipe Guage Pod Pillar w/volt meter,oil temp. & oil pressure Bullitt Fuel Door dpa43@hotmail.com
Posts: 1,152 |
Just replace the wire. I dont know what the stock can hold but its sooo small. You will get better sound if you change it. It doesn't take too long.
1998.5 T-RED SVT 18" Team Loco 142's W/ Dunlop Rubber 181.2hp@6900rpm/155tq@5000rpm LOTS OF MODS OF EVERY KIND.... ...Am I a guru yet??? No... not yet.
Posts: 730 |
My amp is 65wx4 and the factory speaker wire handles it just fine. I doubt I would want to push 200w through it though. And unless you want to cut new holes in your doors, which I didn't, replacing the factory wires isn't so easy.
Kendall '97 GL Zetec ATX " Nippy "
Posts: 11 |
small speaker wire can handle about 45-75 watts. if you're gonna be using a 200 watt amp, id suggest using 8 or 12 gauge wire. for 2 reasons, 1. it will bring more power to the speakers thus sounding better 2. it will be easier to wire than using stock speaker wires
96 Contour GL I4 Nothing Done except for audio Sony Head unit--replacing in the near future 2 12" MTX 6000's Optimus 400w amp--good ol' radio shack 5x7 kenwoods rear door--upgrading speakers this summer Strobe lights in the grill adding undercarriage lights soon
Posts: 816 |
small speaker wire can handle less than 45 watts for clarification. stock speakers are 22 watts.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 139 |
my door speakers are getting 60x 4, and it seems to be doing fine through the stock wiring, but then again, ive never heard it any other way, so it may work out better if i upgrade, who knows. maybe next time im bored and looking for 2 hours to kill ill rip it all out
Posts: 79 |
Just out of curiosity, what speakers are you running a good 200 watts to apiece?
Old - 95.5 SE with lot's of mods. New - 98 Black SVT with few mods.
Posts: 1,447 |
Originally posted by 95Mike: Just out of curiosity, what speakers are you running a good 200 watts to apiece? A better question, what amp puts out 200x4 at 4 Ohms :p EDIT: or 4watts x 200 channels...j/k
Posts: 1,152 |
I am pushing around 100 watts to my Boston Components up front and about 80 to my vegas in the rear. I am sure the factory wires will work but since I had everything taken apart I figured I would replace it all.
Posts: 108 |
Its actually 2 separate AMPS that are 2channel X 200 watts = 100 watts per channel max. I guess I will have to replace all the wiring and end up drilling new holes in the doors.
