my 98 svt has been vibrating at all speeds, accelerating and braking, but severely when I turn left. I just replaced the LCA and can't figure out what it is. Yes I did a search but nothing found there helped. Any suggestions are appreciated...:????
98 SVT Mostly stock..focus shift tower, fog light mod... kickin free-air stereo
From what little you have said, I would suspect a CV joint or CV shaft.
Man, I would check the minor stuff first, go get your wheels balanced, cause if you have any lateral run-out then you're gonna get a little bit of a shake. I would just have your tires checked first.
1989 Toyota Corolla (Totaled, now father car) 1990 Isuzu Trooper (Sold for more than bought) 1998 Ford Contour SE (Totaled in moutains) 1990 Toyota Supra (Blown head gasket) 1998 Ford Contour SVT (So far so good ::knocks on wood::)
The first thing I'd do is rotate the wheels and see if the vibration moves to the rear. Gotta start with the simple (and cheap) stuff first.
1999 Ford Contour SVT #900/2760 (SOLD) 2005 Mazda 6s 2003.5 Mazdaspeed Protege 1998 Ford Ranger 4x4
9
I had a similar problem with a rebuilt axle, replaced it again and no more problems. It would shake pretty hard on the freeway and get worse upon acceleration.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
