N
NateCox Offline OP
N
Should I just run a wire to a power lead on the fuze box? (I have a switched power on from my HU to turn the amp on and off).
Or should I buy a kit to hook to the battery?
I'm completeing my system and should install next weekend.
1: Sony HU 40 Watts/Channel with RCA pre-amp outs
2: Jenzen 5 Channel Amp, 50 watts/channel and 200'ish to sub
3 pioneer speakers in door 120 or 150 watts each
4: Krutchfield amp bypass kit
5: 8 inch 250 watt sub to put on rear deck. Although I don't have a box for it....
Does a sub sound okay in the trunk without a box? I noticed a small round hole in the trunk deck. I'll mount it there so the sound can come through (I'll probably have to cut some insulation away)
Thanks all!
Nate
Knu Konceptz 8ga Amp Installation Kit
Power from the battery.
Check out bigmoneyracing's Rear Deck How-To if you want to mount the sub "free-air" under the rear deck.
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
N
NateCox Offline OP
N
Yeah, I printed out that how-to. That should work fine.
I'm going to check out radio shack this weekend for the wiring. if it's cheaper to buy online I will. I actually need 4 RCA cables...
Thanks!
I
I
definately run it from the battery.
i have a switch in my car for the amp, im using the remote wire. works fine.
96 Contour GL I4
Nothing Done except for audio
Sony Head unit--replacing in the near future
2 12" MTX 6000's
Optimus 400w amp--good ol' radio shack
5x7 kenwoods rear door--upgrading speakers this summer
Strobe lights in the grill
adding undercarriage lights soon
From battery, kits aren't too expensive and are easy to install. you could also build a genarator in u'r back seat to power it.
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
Moderated by  dnewma04_dup1
