I am assuming this 2-channel amp is 2-ohm stable. If it is, you can run all 4 speakers, but you may be over powering them, since when you go from 4 to 2 ohms your power usually jumps up quite a bit. However, to do this, run channel 1 down the driver's side. + from amp to + on speaker 1. + on speaker 1 to + on speaker 2. Same on negative.
Use channel 2 for the other side. That will give you a 2 ohm load.
I am not responsible if you blow your speakers.
Ride: 2000 T-red SE Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
