Pole120 Offline OP
i'm in the process of installing an S2000 antenna\base in my SE, but i can't figure out how the hell to remove the stock base. search gave me no details.
thanks
josh
Does your car have the power antenna or the stationary antenna?
I can tell you how to remove the antenna base if you have the stationary antenna. First, you have to open your trunk and pull back the trunk liner to access the antenna base. Then you unplug the antenna wire from the antenna base. Then unbolt the long shiny bracket that braces the antenna base. Then, hold the antenna base steady with a wrench, inside the trunk, and unscrew the antenna from the base. Then use a special antenna wrench to remove the chrome nut with notches in it (the chrome nut that is just above the fender, on the outside of the car), while continuing to hold the base steady with a wrench inside the trunk. That's all there is to it.
An antenna wrench is a flat, thin wrench with little pegs that fit into the notches on the nut. PM me if you need an antenna wrench, I may have an extra one I want to get rid of. And PM me if you want to get rid of your old antenna base. I'm looking for one.
Pole120 Offline OP
thanks.....got it out, found it in the archives.
i just installed an s2000 antenna\base and a signal amp.
what does that look like?
thanks
josh
I wouldn't know.....mines shaved
Justin 98.5 CSVT # 4887 of 6535 (born 2/28/98)
Pole120 Offline OP
looks like an s2000 antenna and base on a contour......antenna is about 7" tall.
