H
H
Just a quicky - has everyone had better luck faceing thier boxes foward or faceing back for sealed boxes?
confused laugh Thanx!
From what I've read in audio mags, below a certain frequency, the orientation of the subs make no difference - but I forget what the threshold is.
Eric B.
Ottawa, ON, Canada
98 Mystique V6 5spd. Toreador Red
Modified Airbox with K&N drop-in, Cool Blue bulbs, Homemade solid brass shifter knob, Sony CDX-L300 head unit
http://photos.yahoo.com/LBuzzer/
H
H
Maybe I should just toss it in there and move it around until I find a good spot - I have a single 12 fireing to the right side of the car, it works but I'm now getting 2 10s , kinda changes everything.
traditionally it would work better in cars with our kinds of trunks to face the subs firing backward, so the waves bounce off the large surface of the back of the trunk, this usually gives you more boom
now if that was a ported box could you fire the sub fowards and the ports in the trunk?
Black '98 Contour SVT
#162 of 6535
-Indiglo Gauge cluster-
-Kenwood KDC-X815-
-Audiobahn ALUM12x sub-
-Audibahn 18001d Digital Amp-
-Audiobahn 1.0 farad cap-
-LED side markers/washer nozzels-
-KKM Intake - Bosch Plat. +4-
-Custom Exhaust - NO res.-
-Sho Shop off road Y-pipe-
-Fog light fix - THX-Fix-
-Koni strurts - Roush springs-
Mine fires back
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
9
9
If you can place the box right up against the back seats, that is your best bet, firing towards the rear. I have a single 10 firing towards the front, but it is in the rear of my trunk. Placing it that way helps the sound seem like the bass is coming from the doors more than the trunk. 2 10's will be different though, they give a lot better and more fulfilling sound, so i would face them to the rear
99 Tropic green svt
Custom Stereo
borla cat-back
22mm bat rear sway bar
custom K&N & heatshield
215/40/ZR17 Rubber
jimmkreider@yahoo.com
Originally posted by Hi-Liter:
Maybe I should just toss it in there and move it around until I find a good spot.
You gave yourself the best advice....
All I know is with ported, the ports go near back seat and subs face rear.
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
Originally posted by dnewma04:
[b]Maybe I should just toss it in there and move it around until I find a good spot.
You gave yourself the best advice....[/b]
WERD
Beauty is in the ear of the belistener. confused
Mine faces rearward if it matters.
Moderated by  dnewma04_dup1
