#90817 06/01/02 04:13 AM
E
E
i got a ? which speaker will performe better a battery with a high db or one with a low db?also the lower the hz the better?i really want to know.
thanks
99 Contour
JOSE
AIM:elflaco1981
#90818 06/01/02 05:21 AM
Umnn
Hz is a mesaure of frequency. Low pitched sounds (bass) are low frequencies and high pitch sounds are high frequencies.
Joel Falkenberg
#90819 06/01/02 04:03 PM
db is refering to sensitivity. its how loud a speaker plays with a certain amount of power. for instance a speaker with a sensitivity of 92 db should play twice as loud with the same power as one with 89 db. the higher the louder mostly
HZ is frequency. low notes=low numbers, high=high. the human ear can hear from between 20-20,000 hz.(my system does 18-32,000 hz, cool, eh? wink ) to give you an idea where things are, bass drums are probably around 40-50 hz, singers are around 500-1000 i believe, cymbals probably in the 6000-7000 range, etc.
#90820 06/01/02 08:32 PM
There's only one problem to efficiency ratings. Every manufacturer measures them differently as there's no standard, and some exaggerate them (through testing methods) to make their speakers appear more efficient.
I had some 90dB Pioneer speakers that produced just about the exact same volume level as some 94dB Audiobahn speakers given the same input. I put one in each door of my truck to test their measure of efficiency, and to my ears they sounded equally loud no matter the volume setting.
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
#90821 06/02/02 01:44 PM
E
E
so the more db the louder the speaker and the lower the hz the finer the music.it picks up the the hard lower notes.
99 Contour
JOSE
AIM:elflaco1981
#90822 06/03/02 03:34 AM
well, the higer db means louder pretty much, yeah. but hz is different. a speaker plays a huge range of different notes. a subwoofer is pretty limited though, you probably only want it to play notes 100 hz and lower. mine play 80 hz and lower.
Moderated by  dnewma04_dup1
