When I tried to start my 96 contour zetec with the automatic transmission, it would crank and then just not do anything. Thinking it was a dead battery I tried to get a jumpstart. That didn't work. I have taken the battery to get tested at O'Reilleys and it checked out good and only took about five minutes to charge it all the way. We put it back in with the same results. The headlights work just fine, and do not dim when I attempt to crank it. I'm wondering if it's my starter or not. If so, is it easier to get at it from the top or the bottom? Any ideas would be helpfull. Thanks in advance. Josh
