#1176447 02/05/05 12:16 PM
This was asked before, but I read the 3 pages worth of replies and couldn't see that the guy actually got a specific answer...
Does GM's Syncromesh fluid work well in the Contour's transaxle, or should I stick w/ something like Redline' ATF?
Thanks
#1176448 02/05/05 02:12 PM
It pays to read. Didn't find it at first, in the archives, then I remembered to search some of the current topics.
I'm not having an issue w/ shifting, so I'll maybe try Pennzoil's Syncromesh...
Will I still need the FM? If so, about the 2 ounces?
#1176449 02/05/05 02:25 PM
Hi,
It's me again.
With the Syncromesh, I'm guessing 'no' on the FM...correct?
Is this thing on?
#1176450 02/05/05 03:46 PM
Today?
Thanks,
#1176451 02/05/05 04:05 PM
E
E
Replies are slower over the weekend because people are not at work where they have access to a computer and are bored enough to be on it all day, or, they are sleeping in.
· Jon Miconi · Coming Soon! · 01 Cougar · 98 V70R
#1176452 02/05/05 04:48 PM
Or they're telling me to f-off, in a real nice way
#1176453 02/05/05 06:46 PM
GM Synchromesh is supplied by Penzoil and is the same as Penzoil Synchroshift.
Of the various fluids that CEG members have tried and reported on, I don't remember much about Synchromesh or Synchroshift. I suspect that it would benefit from 2 oz of friction modifier. I believe that it is a GL4 gear oil and should be fine.
Here are some of the other products that have been used:
Mercon (factory fill),
Mercon with friction modifier,
Mercon V (with or without friction modifier)(works better with friction modifier)(a semi-synthetic multi viscosity blend similar to ATF+4 except for much less friction modifier),
Mobil 1 ATF (which is a full synthetic Mercon) with friction modifier (also known as the "cocktail"),
ATF+3 which is already very high in friction modifier and needs no additional (works extremely well),
ATF+4 which is the latest spec from Chrysler and mostly replaces ATF+3 (is either a synthetic blend or a full synthetic, Chrysler won't reveal it's composition)
Ford full synthetic MTX honey colored GL4 (factory fill starting in January 2000 as well as factory fill on Focus)(also specified for replacement or top off of earlier MTX75 transmissions that had Mercon for factory fill)(works best with 2 oz of friction modifier)(some have speculated that this is Penzoil synchroshift's more rare synthetic),
RedLine MTL and MT90 (of the two MTL seems to have a more loyal following)(It is reported tha MTL does not need additional friction modifier while MT90 does)(both are full synthetic)(one is more like GL4 gear oil while the other is thinner more like atf but I don't know which one is which).
I personally have used ATF+3 and Ford honey with added friction modifier as well as ordinary Mercon in my own car. I have Ford honey with added friction modifier in it now. I think that it is about the same as or slightly better than ATF+3. ATF+3 is a huge improvement over Mercon. I have three quarts of ATF+4 to try when it is time to change the fluid again in about another 20,000 miles.
Probably more than you wanted to know.
#1176454 02/05/05 08:47 PM
[snip]
"Probably more than you wanted to know."
Not more than I wanted to know...just right.
Thanks.
I have some +3 fluid on hand, so I think I'll give that a try!
#1176455 02/05/05 09:27 PM
Pennzoil's Syncromesh is the same specs as GM's Syncromesh. The only diffence is (IIRC) GM's is part synthetic while Pennzoil's is full.
No FM is needed.
BTW you need to either "read better" {again} like you posted to yourself or be a little more patient.
The information I just posted has been posted by myself numerous times before and demanding answers to come in a 1.5 hour window very early on a Saturday morning is being a little over anxious.
#1176456 02/05/05 10:06 PM
Yes, mother
