Posts: 93 |
Please help, I need to order this on Monday. Thank You
2002 Subaru Impreza WRX
2001 Mercury Cougar
Posts: 9,602 |
The SPEC is a lightened Fidanza... "Supposedly"
I know for a fact the SPEC is actually lighter then the Fidanza is rated.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 93 |
On the cougar board the Fidanza is winning, but here SPEC.
2001 Mercury Cougar
Posts: 7,025 |
If your going to get a SPEC clutch, might as well get a SPEC flywheel. IIRC, I think some people that had the SPEC clutch and flywheel didnt have the clutch chatter either. I have the SPEC and fidanza and have the clutch chatter, but I honestly could care less.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,190 |
the spec clutch and flywheel are balance together so you don't get this chatter or any problems on installation. Fidanza only uses grade 8 button screws while spec uses grade 10. I would go with the spec.
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Posts: 3,867 |
Originally posted by svtProdigy: the spec clutch and flywheel are balance together so you don't get this chatter or any problems on installation. Fidanza only uses grade 8 button screws while spec uses grade 10. I would go with the spec.
Yeah, but this one goes to 11.
Function before fashion.
'96 Contour SE
Posts: 1,190 |
#702 of 2150
Posts: 2,469 |
Originally posted by beyondloadedSE: If your going to get a SPEC clutch, might as well get a SPEC flywheel. IIRC, I think some people that had the SPEC clutch and flywheel didnt have the clutch chatter either. I have the SPEC and fidanza and have the clutch chatter, but I honestly could care less.
I run spec1 clutch and fidanza and get the slightest amount of chatter. My buddy runs a spec2 clutch and spec flywheel and he has zero chatter. So yea
Posts: 417 |
i am planning on fitting a lightened flywheel on my mondeo zetec soon, i was going to get a Fidanza. i cant find a SPEC one available anywhere?
has anybody had any problems with crap idling, stalling when slowing down for junctions etc with the lightened flywheel?
Posts: 9,065 |
Ummmmm, spec gets their flywheels directly from Fidanza...I have a hard time believing that they change all THAT much.
