#90580 05/25/02 02:17 AM
Hi there,
I've been researching somewhat on the car audio forums, but I still have a couple of questions..
1. To power the subs (placed in the trunk) I know you need to run a wire from the battery to the amp. Is there a place where I can leech the power of off something near the glovebox? How does this work?
Also, which methods of routing the RCA cables do you find worked the best? Along the door line, or down the center console?
Thanks!
'99 T.Green SVT #1925
yeah, its got a few mods
38,800KM and counting...
MY SVT ALBUM
E
E
Originally posted by Guntaker:
Hi there,
Thanks!
when i ran my wire from the fuse next to the battery there are black patches in the firewall that they come off and just poke the wire throught i used a screw driverand ran it to the trunk.hope that help don't forget to put the fuse close to the battery!the rca i think is easier along the door line.
99 Contour
JOSE
AIM:elflaco1981
How do you regulate the power?... Does your amp stay on all the time or do you have a switch?
Or do you use the deck remote ?
MY SVT ALBUM
2
2
Yep, the remote for the HU works fine. You can also install a switch to turn it on/off. I used to have one in my old car. I would suggest using the HU though... wink
2000 SE Sport V6
Deep Navy CC Metallic
My 2G Sport
I would use the remote wire from the HU. I wired my RCAs along the door line on the opposite side of the amp power cable. If you wire it along each other you may get interference. wink
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
Also, when you connect the power from the battery to the sub... How do did some of you route the cable? From the + terminal which way did you take it through the firewall and to the trunk?
MY SVT ALBUM
I ran all my lines from the radio to the amp under the center consol. My amp is under passenger seat well 2 amps and a crossover. But power comes from the power line that also controls the dome light but with a larger fuse now. Thinking of changing to use the old factory amp's power or run fire wires to the batt.
....Brad
Aviation Electronic Tech's RULE!!
Your born you die
inbetween you work on cars
how can we be so lucky.
99'Mystique Zetec VCT ATX
"CEG" on front and back windows.
10 inch HED series Cerwin-Vega
My ther car is a 1996 4Runner
Sunfire red pearl
with Bilstein shocks, K&N air filter
and Xenon fender flairs
"There is always room for more mods"
if possible, i would use the side panels to run wires, that lets you keep the power cable on one side (probably the drivers side) and the rca cables as far away as possible, on the other side. that helps reduce possible noise that the cables might pick up from the power
Does anyone have pictures of the wires through the firewall and routed around to the battery?
thanks
MY SVT ALBUM
I ran my power cable from the battery through a rubber cover in the firewall on the driver's side to the amp along the side panels. I ran the rca and remote down the center console. I would just use the remote to turn amp on/off(automatic; and why would you need amp on w/o music?). Also I grounded the amp to a screw under the carpet in the trunk behind the passenger side tail light. Sadly though the amp is wired wrong and it'll be another week until I have it going.
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
Moderated by  dnewma04_dup1
