#90577 05/24/02 10:12 PM
biltz Offline OP
ok the output before the factory amp si a low level output. now do you think if i spliced a set of rca's into this output (from my factory cd player) would i get enough to amp a sub from this? if so does anyone know the wireing code from this output (wirecolor=example yellow= + front left) or would a slice after the amp into a stepdown thingy be more realistic???
pauli18@aol.com for questions
99 green svt
asp udp
b-n-m short throw
kkm intake
n the list grows steadily
#90578 05/24/02 11:39 PM
You will want a high level converter, you can then used the amplified (our unamplified) signal. I recommend one by PAC, it has higher rated components internally
#90579 05/27/02 02:17 AM
biltz Offline OP
thanks knu, i was gonna buy another cap from you but im trying to sell everything...than itd be pointless....already got rid of my cd player...
99 green svt
asp udp
b-n-m short throw
kkm intake
Moderated by  dnewma04_dup1
