#90519 05/23/02 05:41 AM
F
FFE Offline OP
F
I'm looking at buying 2-12.5 Pro Boston Acoustic Subs
Now the hard part, I need to find an amp, My freinds brought up names such as Legacy, Crunch, and Pyle (I know off brand)
I would like a amp at a resonable price (won't break pocket book)but reliable with good sound
I'm planning on running approx. 500 watts RMS to each sub
1996 Mercury Mystique stock (so far)
The leading cause of Atheism in the world are Christians, who accept Jesus with their mouth but walk out the door and deny him by their actions.
(*DC Talks greatest hits. track 15)
#90520 05/23/02 11:13 AM
JBL BP1200.1
http://www.broadwaycomputer.com/shop/Product.asp?ProductCode=2002700
#90521 05/23/02 05:04 PM
Get a Soundtream Reference1000 if you can find it.
Should run about $400-$500.
1000Wx1 at 2 Ohms in "High Current" mode.
Pure and clean power.
It's a bit older, but late 90's Soundstream equipment is still some of the best stuff out there.
1997 GL Sport MTX,
Soon to be the fastest proven Zetec around.
#90522 05/23/02 05:24 PM
The reference series had some issues with power supplies. When they worked they were among the best around, though.
#90523 05/23/02 05:44 PM
Or a Soundstream Class A 10.2 Amp. That is what replaced the Reference 1000, if I am correct.
1999 Silver Frost SVT
#2412 of 2760
DOB - 7/30/99
MODS:
BAT Inlet Pipe /w Monster Flow Filter, Rear Strut Brace, H&R Sport Springs, Koni Sport Struts, Panasonic CPQ-DF800u, Baer Brake Kit, Brembo Slotted/Crossdrilled rotors for rear brakes, rear KVR Pads, ASA JS6 17" w/ S-02 Pole Position, B&M Shifter, 22mm Rear Sway bar, Bassani Exhaust. SoundStream Rubicon 604 Amp, 2 SoundStream Class A 5.2 Amps, 2 SoundStream SPL 12" Subs, SoundStream SVX2 Crossover, Rockford Fosgate Capacitor.
#90524 05/23/02 06:42 PM
I heard rumors of a few bad ones here and there, but never actually saw one.
Never had a problem with mine, and neither did any of my friends.
I believe the Class A 10.2 Amp isn't quite as powerful, but has a better S/N ratio.
But I could be mistaken.
1997 GL Sport MTX,
#90525 05/23/02 06:58 PM
i use a Legacy amp in my bronco and it works fine. They are nice and cheap, too. It would be only around $100 for it.
-1988 Bronco II: Blue and silver with 8 shades of rust. The system costs more than the vehicle smile
-1999 SVT Contour: Silver Frost, tinted windows, stock for now...
"Never slap a man that's chewin tobacco"
#90526 05/23/02 07:01 PM
I'm not too sure how prevelant the problem is, and like all quality issues, it was probably overblown. The Class A had a lower power rating into a 4 ohm load, but had the ability to produce the same power as the reference 1000 in high current situations.
#90527 05/24/02 02:01 AM
I really like your choce in subs.
If it's in your range get a nice big Mcintosh amp. laugh
But if not I agree that the JBL BP 1200.1 is a
great value for the power.
Hope it works out well laugh
'98 E0 T-RED CONTOUR SVT
#558/6535
Got Tunes:
Sony CDXC-90, CDXT-65, XDP210EQ
MCINTOSH MC4000M
BOSTON PRO 6.5 COMPONENTS
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
RED NEON INSIDE AND UNDER
THROTLE HANG FIX
RESONATOR REMOVED
#90528 05/24/02 05:19 AM
V
V
I had a soundstream reference 700, and it caught fire after minimal use. However, I also had a reference 300 and it worked great.
vinny "2000 T-RED SVT"
Mods:
kkm
sho shop off road y-pipe
Audio:
Alpine CDM 7874
Audio Control 4.1 EQ/Line driver
Mb quart rsb 215 comp.
Mb quart rsc 216 comp.
blueprint 1001 sub
2 Phoenix Gold qx2180 amps
Moderated by  dnewma04_dup1
