#90377 05/16/02 11:34 PM
which is the best setup for our cars?
front towards the inside, or rear into the the trunk...
oh and where do you have your amp ground going?
(limited to what came with my srotch (sp?) kit...approx. 2-3 feet.
thanks in advance.
later
MP
"Corrasant--um that doesn't compute--um--wait--You're under arrest!!"
`00 Mystique GS
2.0 zetec
ATX
Ghetto air intake
12" rockford in the trunk
Well, you can use the search function and find a lot of stuff about this topic. I prefer the sub facing the back and I put it in the corner of the trunk closest to the rear. Also, I have my amp grounded under the center rear seatbelt anchor under the back seat.
1998 SVT Contour
Rock Chalk Jayhawks!
Black/Midnight Blue
#457/6535
Born: 4/24/97
I have mine firing to the rear also . I grounded my amp to the back of the taillight housing (there is a bolt on it)
Its not much but i hope it helps
Chris Bertrand , !!16 years young!!
1995 Ford Contour Gl 2.5 V6 MTX
My DIMS (DO IT MYSELF) Achievements:
Performance Mods: None
Audio Mods:Jvc head unit, 6x9's in all doors , Sony XM-752EQX amp, 2 Sony Xplod LS-1235 12" Subs
Video Mods:Blaupunkt DVD-ME1, 2 5" monitors in sunvisors
Aesthetic Mods:Neons, Streetglow El Shift Knob
Commando LCD Pager Alarm
Many Mods To Come.......
thanks...oh my search button is broke..
j/k...thanks
later
MP
`00 Mystique GS
2.0 zetec
ATX
Ghetto air intake
I have mine facing rear towards the trunk. I tried them both ways, but the way I have them now seems a little bit louder.
Warning: Management is not responsible for lost or stolen virginity.
'98 Zetec MTX
17 x 7 Enkei RS5 w/ 215/45/ZR17 Goodyear Eagle GS-D Import tires
30%Front/25%Rear Tint
JVC KD-S570, Clarion APA1200, 2 Soundstream Reference 10"s
"Powered By Ford" seatbelt pads
Pre98 Sail Panels
Removed resonator
Magnaflow muffler
uh ... I have my subs facing up !!!
The only way I could fit those damn things in there without building a wall int he backseat.
Jared.
-SVTweeter-
http://svtitan.com - view the Ride!!!
98.5 Black SVT
PIAA blue platinum fogs,CATZ MSC in factory fog holes 18x7" Chrome Neeper Titans
KKM Induction, (4) 15 inch Solo-baric L7's in the trunk, (2)Earthquake PHD2 amps, Memphis 3004 powering (4) kicker 6.5 subs in doors,
Imaged Dynamic CD2 Horns powered by Memphis st150 amp.
5% tint around, side markers, Bassani exhaust, Ground Control Coil-overs w/ Eibachs,
Koni Struts & blackened back Reflector, B&M shifter
148.7 db May 6th - DB Drag
Yet to drag with new amps ... can't wait
shopping cart spoiler - I can fly baby!
mine fire back
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
9
9
It doesn't matter, but if you fire them towards the front make sure that they are in the very back of the trunk, and not right behind the seat. Also, for the ground, the worst thing you can do is place the ground by the seat belt or seat bolt. You never want to share a ground with or near anything. Drill a new whole in the metal of the trunk(bottom)about 6 inches away from the amp. Don't drill in the gas tank
99 Tropic green svt
Custom Stereo
borla cat-back
22mm bat rear sway bar
custom K&N & heatshield
215/40/ZR17 Rubber
jimmkreider@yahoo.com
orginally posted by SVTweeter:
Jared.
that is f'in sweet...
how do you like them things?
later
MP
`00 Mystique GS
2.0 zetec
ATX
Ghetto air intake
9
9
Don't want to share ground?!? confused It is not bad to share grounds in systems in my previous system and in my 2 friends systems I helped install we had grounds being shared between multiple amps and evening a cap sharing with no problems. I have spoken with several local installers about this on occaision and they all say it is "perfectly ok."
LooneyMP what kind of amps are you using for your system?
Quality is remembered long after cost is forgotten.
...Oh sorry I guess I am just another stupid kid who doesn't know anything...
Moderated by  dnewma04_dup1
