#1169801 01/29/05 01:52 AM
E
Edith Offline OP
E
Can anyone help with my problem. Several times I have went somewhere in my contour SVT and later when I get back into the car in wouldn't start. It doeen't make any noise. Everything works but cranking. I have to sit for about 10 to 15 minutes without trying to turn the car over and it will fire up. It has happened three or four days apart and then it stopped for three to four months.It has been about a month since it happened. I am just scared one of theses days it won't start.
#1169802 01/29/05 02:06 AM
bad cam sensor or ECT engine coolant sensor
what kind of spark plugs do u have?
98 svt sil/blu 3.0 oval heads full P&P, msds headers,bat kit,2,1/2exhaust 30 inch glasspack and 2 spintech mufflers 14.78@94mph with my mechanical arm i can shift gears in less then a twentieth of a second for sale $7000
#1169803 01/29/05 02:37 AM
E
Edith Offline OP
E
I use motorcraft. Are those sensors where I can change them myself?
#1169804 01/29/05 02:41 AM
E
Edith Offline OP
E
I have notice sometimes my anti theft light is not blinking but it starts blinking like it should. But still doesn't crank until about 10 to 15 minutes. At first I thought it might be in my key but my other key won't work either.
#1169805 01/29/05 02:43 AM
Welcome to CEG!
LowBudget is right if the engine cranks.
If the engine does not crank at all, first see if the PATS light flashes (passive anti theft system)when the key is inserted.
It could also be the start relay, the connection to the starter, or the starter itself.
#1169806 01/29/05 03:50 PM
E
Edith Offline OP
E
The PAT light will be blinking sometimes not like it is suppose to. When it does get back to blinking normal then it will crank within 5 minutes. Yes the PATS usually is not right when it has happened.
#1169807 01/31/05 11:25 PM
Have you tried the other keys to the car?
As with any newer car you should have a minimum of 3 good keys.
If the othe keys give the same problem, obviously the security system in the car is the problem.
If that key is the problem, remember to copy and program a new key into the system.
Unless someone with experience can address this, please search. There are many threads on this.
#1169808 02/01/05 02:26 AM
1
Hey I know it's off topic, but we have another SVT in NC? Where ya at?
#1169809 02/01/05 01:30 PM
Make certain that you have only ONE PATS key on the keychain at a time.
Sometimes, multiple keys at the inductive pickup loop around the ignition switch can interfere with each other.
Steve
#1169810 02/07/05 03:28 AM
E
Edith Offline OP
E
I am in Greensboro. Where are you at?
