Posts: 16 |
Ok, here is the situation. My SVT Contour is throwing the P0420 code, which is a bank 1 O2 sensor code.
From what I have been able to read up, its not the sensor itself that is typically at fault, but the pre-cat. There are a few remedies that will temporarily fix the code (involving B12, cooking the cat, etc) but the inevitable fact of the matter is that the cat is toast and will need to be replaced. My car is past the 70K mark (just turned 80K), hence past warranty replacement (CA car) and as you know they are quite costly.
What seems to be the preferred choice is two options: 1. Gut the pre-cats and run MIL eliminators 2. Replace pre-cats & manifolds with headers (MSDS) and use MIL eliminators.
Both 1 & 2 are now fully dependant on the main cat now, most likely a new Y-pipe/cat combo added at the same time as the headers if that option is taken.
I fully understand the concept of the MIL eliminators, they "fool" the ECU into thiking everyhing is ok with the O2 sensors even though the sensor signals are dynamic, transitioning between 0 & 1.0V depending on the mixture.
I also understand that the pre-cats are used primarily during startup and as long as the car has been warmed up, it should pass the sniffer part of the test. I'm hoping, with the engine bay being so packed, its will make it difficult to see if the pre-cats are there or not.
What I want to know, which is why I posted this in the CA part of the forum is... ...who has done this personally? I've read alot of, "yeah I've heard it works or so and so did it". No first hand accounts.
I don't want to drop a G only for things not to work out.
Any input is appreciared & TIA,
-Mike Malone
98 E0 Silver Frost MTX & other various mustangs...
Posts: 2,033 |
gut 'em.
Posts: 3,506 |
im running a 3 liter /hybrid motor with a 11.25 compression...and when i gutted my pre-cats and smoged, it passed...cleaner than my stock 2.5 liter.
You should be fine gutting them, and using the mil eliminators. make sure you warm it up with a good half hour drive before your smog test.
Also, MSDS Headders are a better route as they give you more power, but i did not have the money at the time to get them. MIl eliminators do work!!!
the only probelm is if you go to a goody to shoes shop, they will not smog you if they see the headders. Go to a vietmanies shop, that barely speaks english...they won;t care if you have headders or not.
or if you know someone who knows someone, you can usualy get away with it.
But YES, gutting pre-cats i had no problems passing..and headders are not problem wither , besides mentioned above.
Lupe
Posts: 713 |
Originally posted by Roz 1999 SVT-C:
the only probelm is if you go to a goody to shoes shop, they will not smog you if they see the headders. Go to a vietmanies shop, that barely speaks english...they won;t care if you have headders or not. Lupe
lmao
98 svt sil/blu 3.0 oval heads full P&P, msds headers,bat kit,2,1/2exhaust 30 inch glasspack and 2 spintech mufflers 14.78@94mph
with my mechanical arm i can shift gears in less then a twentieth of a second for sale $7000
Posts: 3,045 |
does anyone here know the official reason why the headers are not carb approved?
00 black/tan svt, #2052 of 2150, born 2/1/00
formerly known as my csvt
"Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
Posts: 1,036 |
Originally posted by my csvt: does anyone here know the official reason why the headers are not carb approved?
Because they eliminate the precats. And even if they did have precats, Marty would have to go through the process of obtaining an EO number, which means the headers have to be tested.
Getting back on the subject, try replacing the O2 sensor first. It will be cheaper and should get you through your smog check.
dion
98 SVT, 200 whp/190 lb. ft tq (tuned by ADC), 3.0, P&P heads w/2.5L valves, optimized TB, MSDS, SCA 2.5" catback, SHOshop UIM/LIM, underdrive pulley set, TD's, Koni/H&R, BAER/TCE, Progress, CF1 products
Posts: 302 |
i did it on mine, and i have passed smog 2 times, once with the 2.5 liter and once with the 3 liter. its way cheaper then buying the precats.
98 svt contour, magnaflows, sho shop intake, sho shop high flow cat, no pre cats, custom cougars short shifter, 3 liter hybird engine woo hoo im happy, and just added a dmd underdrive pulley.
Posts: 16 |
Thank you all for the advice.
I really need to spend some maintenance time on the car (remove/clean/reinstall) the TB & UIM. Need to see how hard it is to remove the exhaust/manifolds/y-pipe.
For now I am just going to run a can of B12 for a fill up or two and change the upper 02 sensors.
Hopefully that will buy me enough time to finish my 84 SVO Mustang (Fabulous Fords Show at Knotts) and then I can give the Contour some quality time.
Thanks again, the input is appreciated. For you local SD people that may read this, I hope to attend the meet in Feb. If I am in town I s/b able to.
-Mike Malone
