#90235 05/13/02 01:24 PM
Ash Offline OP
any downside to going this route? Instead of two or three amps Im looking at getting 1 five channel amp! Good Idea or bad? I already have a punch 800a2, but Ill get rid of this If I go the 5 channel route. Any good ones in paticular that the stereo guru's whould suggest? Thanks
98 sliver frost SVT
now w/100,000+
#90236 05/13/02 01:59 PM
5 channel amps are great, i have 0 problems with their use.
What is your budget and what are your system goals?
#90237 05/13/02 02:36 PM
Ditto!
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
#90238 05/13/02 03:07 PM
It is my civic duty to inform you that Alpine make nice amplifiers. Dave will try to find you some obscure thing like a Macintosh or a PPI, or maybe an a/d/s. If he does, get what he tells you to as he knows everything there is to know about car audio, as he is a nerdbot 2000.
MRV F-450
? Max Power (EIAJ) 150Wx4 (4ohm; Stereo) 350Wx2 (Bridged 4ohm;)
? 12V RMS Continuous Power 4ohm; Stereo (0.08% THD) 50Wx4 2ohm; Stereo (0.3% THD) 70Wx4 Bridged 4ohm; (0.3% THD) 140Wx2
?14.4V RMS Continuous Power 4ohm; Stereo (0.08% THD) 80Wx4 2ohm; Stereo (0.3% THD) 100x4 Bridged 4ohm; (0.3% THD) 200x2
? S/N Ratio 100dBA
? Frequency Response: 10-50kHz
? 12dB HP/LP Crossover
(30-400Hz)
? Extra Large Gold Plated Terminals with Wire Insert Capability
? Top Panel Power LED
? 4 Volt Input Capability
? Continuously Adjustable Crossovers
? DC Straight, STAR Topology
? DC-DC/PWM MOSFET Power Supply
#90239 05/14/02 12:27 AM
H
H
that's not alpine's 5 channel amp? their 5channel amp is like 50x4 and 220x1 (something like this)
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
#90240 05/14/02 02:54 AM
I pulled this directly off alpine's site, so yes, this is Alpine's 5 channel amp (V12) There is the VPower model but it isn't quite as good.
#90241 05/14/02 03:15 AM
I guess Alpine's site has the 4 channel info in the 5 channel's page... typical. Alpine can build nice electronics but ask them to make awebsite and they toss out this crap mad
http://ecominet2.alpine-
usa.com/pls/admn/item_info1a?p_item_name=MRV-F450&p_category=40&p_subcategory=130&p_main=10
You have to highlight the whole address and paste it to get to the webpage
#90242 05/14/02 02:22 PM
Ash Offline OP
right now I have a punch 800a2 running two 12 alumapros. But I was thinking of either keeping those and getting a punch 200a4, or 400a4, and components up front and something basic in rears. Or starting over and putting componets up front something basic in doors and getting new subs and running all this with a 5 channel amp. Only 5 channel amp Ive seen in person was the JL. Not a thing wrong with the amp and speakers I have now so thats making the decision tuff. Also for componets I was the thinking the boston acoustic pro's or they have a three speaker set up also. Any ideas or guides in the right direction would help. money wise I dont want to go hog wild but I also dont mind paying for good equipment, and I probably wont be entering any competitions, but I would like a kick a$$ setup.Thanks again guys!
98 sliver frost SVT
now w/100,000+
#90243 05/14/02 02:23 PM
If you already have the sub amp, it may be cheaper to just buy a nice two or 4 channel amp to power the components.
#90244 05/14/02 04:22 PM
N
N
I have a Infinity 5 channel amp that is pretty nice, 50w x 4 + 200w class d sub section. Something is wrong with it though cause it goes into protection when the input voltage gets to 13v. I'll sell it cheap if anyone wants it or anyone have suggestions on fixing it?
-Nick
'00 SVT Silver Frost
KKM Intake
B&M Short Shifter
Richbrook Knob
KKM Pedals
*more as budget allows!
Moderated by  dnewma04_dup1
