#1167931 01/27/05 02:27 PM
1
I got a flat in my front passenger side wheel while going to work the other day. Work is only two miles away and I didn't realize I had the flat until I pulled into the lot, when my driver side wheel started spinning like crazy to compensate for the flat. After this my ABS light came on and has remained even after I got new tires. Is there really something wrong or did the excessive wheel spin on my driver's side trigger something?
#1167932 01/27/05 06:59 PM
1
Nothing? I searched for ABS in troubleshooting but nothing similar to what happened in my situation...
#1167933 01/27/05 07:32 PM
You may have damaged the ABS sensor wiring on that brake caliper. Check the one in the rear if the front checks out OK.
#1167934 01/27/05 07:44 PM
1
Hate to sound uneducated, but, I am in this case. I know "damaged" means "screwed", but can it be damaged and not be visible? Thank you for the reply, BTW.
#1167935 01/27/05 08:16 PM
9
Just a thought, before you throw money at it... Try resetting the computer. To do this, just unplug the negative terminal on the battery and leave it disconnected for a little while. I'm not sure how long it takes to reset it. I usually leave mine disconnected for at least 10 mins...
1999 Mystique LS V6 Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
#1167936 01/27/05 08:30 PM
1
I've already reset the PCM by pulling fuses #4 and #11, and the light remained on. I will check the sensors before I go to work.
#1167937 01/27/05 10:33 PM
Yes, it can be damaged & difficult to notice. The wire may have been pinched or impacted in a way that pulls a break in the wire, but the insulation may only appear to be scuffed. That happening with multi-strand wire would be freakish though...
You can do that pretty easy with telephone wires, just bend them back & forth till the copper wire breaks, but the insulation looks fine.
I really don't know what else to tell you. I don't know much about ABS systems...
