#90143 05/08/02 07:30 PM
E
E
hey if i put one of my subs facing the floor of the trunk will that make alot of bass.what will happen if i do that has anyone done this.
99 Contour
JOSE
AIM:elflaco1981
#90144 05/08/02 07:58 PM
I should not increase the output if that's what you are asking, but it will protect the speaker a bit better than other methods.
#90145 05/08/02 08:12 PM
It can if done right. You can use the floor and some sides as a simple bandpass. But this does require more space than just enough to let the subs work. But the volume calculations would require alot of work with the irregular floor. It would be hard to do and I don't know it the results would be worth the effort. I hope that helps. laugh
'98 E0 T-RED CONTOUR SVT
#558/6535
Got Tunes:
Sony CDXC-90, CDXT-65, XDP210EQ
MCINTOSH MC4000M
BOSTON PRO 6.5 COMPONENTS
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
RED NEON INSIDE AND UNDER
THROTLE HANG FIX
RESONATOR REMOVED
#90146 05/09/02 09:28 PM
E
E
thanks u guys i'll think about if i'll do it i'm not sure.
99 Contour
JOSE
AIM:elflaco1981
Moderated by  dnewma04_dup1
