seriously, can you try to explain that again?
secondly, this should be in the troubleshooting section.
third, have you replaced the wires or not? i cant tell. if not, maybe you are arcing through bad insulation or something of that nature. you have any other problems as well or just pop pop?
edit: maybe also a bad connection between the plug and wire and the arcing occuring between those two? that would make sense if you can push on the top of the wire and make it go away.
or im crazy, and i wont offer any more advice. none of this works anyway if you have replaced the wires
