Page 2 of 4 1 2 3 4
With the setup i have right now, i hit 147.4db, with 1000wrms. We don't have much competitions here, so i don't know about sound quality. I got JL subs, and MB for the front. I have yet to upgrade even more in my system.
Give me more beer and CEG before i get depressed!
AIM/AOL: DBZ Jr
Originally posted by Inspinout:
with my old setup i hit 144 db on the dash..
had it tested at CC for $15 wink
they actually charge for testing SPL? Here, they do it for free. Especially if they know you love car audio.
AIM/AOL: DBZ Jr
1
1
Originally posted by HoosierContour:
Go Dynaudio for SQ, and forget about it!
I'm gonna have to agree. Dynaudio has brought my stereo to life!
2
2
6 speakers:
2 Focal TLR tweeters in "A" pillar, each gets 100 watts
2 SEAS Excel W21EX 8" in kick panel, each gets a 100 watts
2 Image Dynamic IDQ v2 15" each in 2cf sealed enclosure, each gets 400 watts
4 Amps:
XTANT 2200ix
Sony C90 head unit
Sony 4000X Crossover and EQ
Behringer DSP8020 EQ
SPL = 146 dB on the windshield (USAC)
2000 USAC 601+ Consumer SQ World Champ
past 5 yrs IASCA Regional Champ for 601+ Ama
1
1
Originally posted by 2deep2:
6 speakers:
4 Amps:
XTANT 2200ix
Sony C90 head unit
ARGH, I get jealous when I read your stuff!
Anyway, You gonna make Spring Zing again this year Anthony?
Or go Seas and Focal and forget about it. wink
I would.. but too bad no one deals with those brands on this island frown
AIM/AOL: DBZ Jr
yeah, that's unfortunate. shipping probably kills you. If you didn't mind making your own crossovers, the money you could save on making your own components may make up the difference in shipping.
My setup last week:
Eclipse 7002
A/D/S P850
MB Quart 4" in center console
MB Quart tweets in pillar
8" Infinity 80f in the doors
Pioneer 6x8 rear fills
3 JL audio 12w7's in the trunk
3 MMats D300HC modded amps
163.1 DB's
This weeks, and hopefully the final setup I will have:
Clarion VRX925VD
Clarion DVH920
Clarion VCZ635
McIntosh 440m x2 4x50w + 2x100
Dynaudio System 240 7" and tweets
Dynaudio System 360 8" 4" and tweets
Dynaudio MW-150 5"
McIntosh MCC602TM 300x2 @4ohm 600x2 @1ohm
JL Audio 13w7 13" sub 1000 watts RMS
As far as what db's I will hit, I can only assume around the 145 mark, this system will be the ultimate SQ system, not SPL. I have sompeted in SPL for 7 years, this is the first try at SQ. I am sponsored for the JL and Clarion equipment. The McIntosh amps have cost me an arm and a leg, and my first born. The Dynaudio I have purchased most of it off of ebay all brand new except for the 5" mids.
2001 Mercury Cougar
Aerogear WideBody Kit, Aerogear Carbon Fiber Hood
3.0 Hybrid 251hp and 229tq at the front wheels
Eibach springs, Koni Stuts, Aussie Bar, ST200 R Strut bar, OMP front Strut bar, 19" RPM's 235/35-19 Nitto 555's
All Alpine System - IVA-C801, DHA-s680, NVE-N852A, TCS-V430A, TMX-R705, TME-M580 x2, PXA-H900, MRD-M500 x2, MRV-f540 x2, SPS-0829, SPX-F17t, SPX-17m x2, SWR-1021D x4, RUX-4280
http://www.geocities.com/socal_neco/jimmy.htm
Originally posted by Sleeper:
My setup as it stands right now;
Alpine CD Player w/ 4V pre-out
Soundstream BLT (balanced line transmitter)
AudioControl Four.1 (pressing out 13.5V of pure signal)
AudioControl ESP-2 (simulating my center stage)
AudioControl EQX
Soundstream Ref300 (75W x 1 Channel)
--> Lightning audio 1F cap
--> 2 12" Phoenix Gold Saphire Subs (Wired in parallel)
(I have the subs in parallel to decrease to 2ohms, but then I added them in series with 8 50W/50Ohm power resistors, this gives me a super stable 8Ohm load on the amp, it also increase the amount of current, giving me a nice 37.5W per sub actual, but it performs like 300W per sub, this setup is so very beneficial in competitions.)
Soundstream Ref404s (40W x 4 channels)
--> Infinity REF605CS (6.5" w/ 1")
--> Infinity REF5752CF (5"x7" two-way)
The subs are housed in a ported band-bass box.
The box was designed and tuned for the subs (1.75 cubic feet and tuned to optimize 32-64Hz range).
My problem is not the setup but has something to do with the car, my RTA line drops 6dB between 500 and 1kHz. This is also causing my a 12dB loss on SPL. Just wondering if anyone has seen this problem? If its related to a something on the car soaking up the energy at those frequencies. I have dynamat throughout almost all of the car.
Just curious. Why did you feel the need for a Four.1, [with its high output] and a blt in the same set up? And yes, I'm fully aware of the benefits of each seperately. Also, why would you choose an amp known for its high current abilities [Ref 300], and then castrate it with resistors? You could've saved yourself a lot of hassel by just running the amp in two channel mode. Same output...or better.
Ummm. 37.5 watts performing like 300???? Sorry. It's not. I used to have a pair of 300s, and other Ref. models as well. I can't bad mouth them a bit. My 300s were run in 2 ohm mono for over two years without a hiccup. I'll tell you this though, their power in this mode compared to their "per channel into 4ohm rating" of 37.5 watts [with high current switch "on"] is like nite and day. I honestly can't say that their "sound quality" suffered in the least on sub base program material either.
Just my two cents... smile
blk.99svt
n.e.Ohio
Never under estimate the power of stupid people in large groups...
Page 2 of 4 1 2 3 4
Moderated by  dnewma04_dup1
