Posts: 15 |
A leaking intake manifold gasket(s) caused ALL the above codes intermitently. Not MAF, not the IAC valve, not the O2 Sensors. Just an intermitent air leak that was worse when the engine was cold as the clearances were larger around the leak.
The gaskets were shot - a very poor design it seems as over time the rubber material deteriotes.
Posts: 2,408 |
Welcome to the five year club!
Hope you cleaned the intakes out while you were at it.
Posts: 89 |
does any one have pics of before and after cleaning??
R.A
Posts: 2,408 |
TB Intake There are some after pics somewhere, just have to search.
Posts: 15 |
Yes cleanned out the upper and lowwer intake manifolds durring the repairs. They were VERY dirty and a real pain to clean. Used a commercial parts cleaner - forget what it is called as a get a gallon or so a year from a local engine rebuilding shop but it is water rather than xylene based and still cleans out the carbon deposits. Got really keen and used a dremel tool to clean up the intake ports a little as well as there we a couple of bumps in the casting....
Read an MSDS sheet on xylene, (the main component of most "carb" and throttle body, fuel injector cleaners) and it will curl your hair...
Cheers, William
