Truth be told it only effect a very small frequency band. But it does do a good job of more acurately reproducing that limited freq band.
How is this possible? If this was the case, wouldn't ALL speaker makers recommend this style of mounting? I have never seen Wilson Audio do this in thier set of $125,000 speakers
Sound quality would actually be degraded from the air moving across the basket, magnet, spider, etc. Not to mention the God awful dispersion pattern.
It does require as much as 5 times as much power to get the same SPL. But should only require twice as much power to get the same loudness.
Note;
Loudness does not equal SPL (sound pressure level).
I'm not sure what this has to do with the question. I will agree, percieved loudness does not equal actual SPL, but this is mainly seen when compairing 20Hz to 500Hz not 20Hz to 80Hz. The human ear is not linear in it's response. We are dealing with a very small portion of the audio spectrum in this case.
If you do mount the driver backwards, remember you must account for the change in the volume(cubic feet not SPL) of the box.
Just my 2 pennies.
