#1158861 01/18/05 02:05 AM
I
I
hello everyone, i'm an avid neco member and i'm looking for info on the stab-o-shock that came on the svt contours. if anyone has a pic of this and knows whether it will bolt up to a non-svt duratec, any info would be helpful. thanks! p.s. i have searched and came up with some stuff, but i think there's probably stuff i'm missing.
The stab o shock is a waste of time. You're better off getting in on the poly rear roll restrictor group buy that pole20 is running. It'll work better than any stab o shock will.
0
whats the deal with the performance ford torque brace ? the street link, i heard pf when out of buisness. where can i get one at ? it looks beefy enough to replace the stab-o-shock on my csvt.
-2000 csvt silver frost #1619 -magnaflow 14415 -optimized T/B & y-pipe -superchips xgt1 -75mm proflow maf -K&N RU-3530 -fsvt smart pump # 354Z-9H307-BC -spec stage one, LSD -low-tek,a/f,oil press.,volts -B&M short shifter -17" konig gt-r
I have a stab o shock...didn't notice much if any diff.
0
my stab-o is shot i was playing with it when i installed the poly mount insert it was in pretty sad shape but its got a lot of weight on its hands, ;]
Hey dopey!
Read the second post (my first one in this topic) again
Originally posted by Stazi:
You're better off getting the poly rear roll restrictor
