Agreed, for the work that you want done I would shop around a little and look for a somewhat better price. Again if they are going to pull and replace the head then 500 bucks is a good deal. If you have to do every thing then look around. While you have the head off it would be a good time to change the timing belt, water pump, and all the tensioners(SP).
Do you have a Automatic or 5 speed? If you have standard then I would change the clutch if it has been a while. No one is quite sure how much more power you will be putting out with the compression raised. Although your transmission could handle it you might not want to risk it. If you have an auto then at least have the transmission serviced and add a tranny cooler.
Removing the head also means draining the fluids so now is a great time to upgrade to Royal purple coolant and throw in some water weter from Red line. If you are not already using it switch to Mobil One.
Now none of this extra stuff is required but you might wish you had done all this.
