Posts: 11 |
Hey all! First off, thanks for having such an informative forum! It has helped me out many times.
OK.....now for the ugly part! I've got an 1996 contour gl 2.0 zetec with atx and 107,000 miles. For the last year it has ran terribly! It idles rough while in Park and exspecially in gear sitting still with my foot on the brake!
I've replaced and gone through everything i could think of and broke down and took it to the $tealer twice.
Item's replaced/service done:
oil flush radiator timing belt belt pulley's belt tensioner water pump water pump pulley battery plugs and wire's (motorcraft from dealer) ECU puter wiring harness atx position sensor air filter various gasket's replaced coolant temp sensor
It's just getting worse, stalling at light's and forget the A/C in the summer. the dealer recommended replacing the ECU, when i did the car still ran the same. all of these things that i have done have been by the book. please .......any suggestion's or thoughts would be greatly appreciated.
Will
Posts: 8,301 |
-Ken V.
psycho_bass@hotmail.com
Posts: 5,143 |
yeah, thats a very common problem onces contour pass 100K miles... the IAC valve gets sticky.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 285 |
What do you mean it runs rough? Does it seem like it's misfiring or is it just vibrating? It's common for the tranny mount to go bad and allow the transmission to sit on the engine cradle. This will cause a vibration that would be worse at idle, in gear at idle and when the car is under load like with the a/c on. It tends to be confused with a misfire. You would really feel it through the steering wheel. If it's misfiring the dealer should have been able to come up with something because with the OBDII diagnostics it in most cases is sensitve enough to point you to the right cylinder(that is if it is misfireing). Low or high fuel pressure can cause a car to run rough. You can check the fuel pressure at idle and at various RPMs. At 100K you could be looking at a fuel pump or a bad pressure regulator. Also vaccumm lines should not be over looked, but in most cases a vaccumm leak should show up with a code scan.
Parting out 95-97 Contours/Mystiques. Contact me directly at ALFIGOLS@yahoo.com if you're looking for a particular part.
Posts: 610 |
IDLE AIR CONTROL....CHECK THAT OUT!!!!!!!!!!!
2002 Cougar
2.5 duratec/ mtx-75
85,0000
Mondeo ST-200 wheels/BFG KDW NT
black/black
Spec Stage 1
Torsen T-2
Trubendz 2.5 flowmaster dual exaust
apexi s-afc II
K&N FIPK
Posts: 11 |
Wow thanks for the quick replies guys. is there anyway to test the IAV short of replacing it? it is missing really bad and stall's quite often.
Posts: 5,143 |
Originally posted by williamsmithers: Wow thanks for the quick replies guys. is there anyway to test the IAV short of replacing it? it is missing really bad and stall's quite often.
Do you have a check engine light on?
TEIN H.Tech Springs
Posts: 11 |
no code's or anything, just runs terribly!
Posts: 5,143 |
your best bet is an IAC valve.
TEIN H.Tech Springs
Posts: 76 |
Check all your vacuum hoses for air leaks also m
