Posts: 1,040 |
Originally posted by SVeeT: ... I have been instructed to unplug the antenna from inside the trunk, but there are a couple hookups back there and I don't want to break anything. I already unhooked the thick black cord leading upto where I thought the antenna would be, but it still went up... I think the wire you unplugged was the rf lead to the antenna. This would have no affect on up/down but you would lose am reception. FM would be ok in area of strong stations. If you want antenna always down simply pull black 8 pin connector from antenna control module mounted to antenna mast in trunk. EDIT: See note on later post re connector color.
Posts: 63 |
Buy a SONY unit! Mine automatically brings down the antenna when in CD mode. You may want to check if your unit has this capability or not. If your running the trigger wire from the HU it will control the whole operation.
If anyone was following my follies with the power antenna, it's done! Installed an after market, Harada unit, today. Ironically enough its the same piece as the Ford OEM but with a slightly different wiring set up. Works like a charm!
Nrsstc Toronto, Canada 99 Mystique LS V6 ATX, Cabernet Red, Window tints, Stereo mods, A6 Side Markers and newly added SVT exhaust. Coming soon: SE Skirts
Posts: 1,444 |
to beat a dead horse here, take the power antenna wire from the hu and split it, running each end to the switch of choice. once u split it did u extend the wiring by soldering on some more wiring to reach the switch.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 144 |
[/qb][/QUOTE]I think the wire you unplugged was the rf lead to the antenna. This would have no affect on up/down but you would lose am reception. FM would be ok in area of strong stations. If you want antenna always down simply pull black 8 pin connector from antenna control module mounted to antenna mast in trunk.[/QB][/QUOTE]
I was understanding everything until you gave me your directions. In english this time! If you want antenna always down simply pull black 8 pin connector from antenna control module mounted to antenna mast in trunk.
'99 SVT Silver Frost Love to read up on any mods. Any recommendations, feel free to let me know. AIM: PlayT88
Posts: 247 |
If your HU has "traffic info" and it is on turn it off the antenna should go down.
Posts: 1,040 |
OK if you simply want OEM antenna to stay down:
Peel back carpet at pass side of trunk to reveal antenna mast/motor assembly. You will see one coaxial rf (radio frquency) cable that comes from front of car and plugs into a socket on base of antenna mast. You will also see a brown plastic antenna module box mounted to antenna mast with a black electrical connector. (There is a connector that also goes to just beside motor - ignore). The wires to the black connector come from driver's side of car, running across rear of trunk.
Disconnect black connector to prevent antenna up/down operation. Connectors usually require a plastic locking tab to be released before and while you are pulling apart.
Posts: 345 |
hmouta - There's enough slack in the harness to add the switch with extending the wire length. You are only moving it a couple of inches.
AL
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
Posts: 195 |
Break it off, attach a 4foot wire and let flow like the wind!
Posts: 144 |
I'll take a look at these again, thanks guys. Hi-Liter your a goof!
Posts: 144 |
Disconnect black connector to prevent antenna up/down operation. Connectors usually require a plastic locking tab to be released before and while you are pulling apart. I have a WHITE connector that goes into the Brown plastic modedule box. (You listed to pull out a BLACK connector) Am I not looking in the right spot? I tried to pull out the WHITE connector from the box, but it didn't happen. The plug is well in there like it's not supposed to be removed or something. (I know that there is a lil lock release)
