#1156782 01/14/05 07:12 PM
mi5pal Offline OP
I recently had my fuel pump replaced (under ESP warranty) at the dealer. They wanted to also add on a $200 charge to have my injectors cleaned, according to their readings, the injectors were working at less than 100%. Is there a cheaper way of having them cleaned?
#1156783 01/14/05 07:17 PM
Yes. Go anywhere but THAT stealership.
Normally the injector cleaning service is $50-70.
You can do it yourself with a premade kit for about half that. NAPA should carry them.
#1156784 01/15/05 07:33 AM
couldnt you just spray or let them soak in berryman's for a while?
98 csvt t-red.. sho-shop intake, b&m, fidanza, spec1 clutch, Torsen, DMD,optimized Y& TB, Brullen, rear strut bar,h&r's,17" konig traffik's. "I say what I mean and I do what i say"
#1156785 01/15/05 07:33 AM
mi5pal Offline OP
Thanks for responding, I will look into that this weekend, should have time with the extended weekend and all.
#1156786 01/15/05 07:46 PM
That doesn't clean inside the injectors.
The pintle is closed normally and the injector does not take in fuel (fluid) not under pressure.
#1156787 01/16/05 03:06 AM
A bottle of high quality injector clean added to the gas does wonders for cleaning up the injectors. I like RedLine and Techron. Unless the injectors are really bad, this usually does the job. Do yourself a favor and clean the throttle body at the same time. Doing a chemical cleaning on the cr of the intake manifold will also help. If you do those three things you will be very pleasantly supprised at how much better the car runs.
#1156788 01/17/05 05:24 PM
pull out your injectors and run power to them and have the entrance side of them in some brake clean, so when their powered they swuirt brake clean, that way your cleaning them, that way its free
2002 Cougar 2.5 duratec/ mtx-75 85,0000 Mondeo ST-200 wheels/BFG KDW NT black/black Spec Stage 1 Torsen T-2 Trubendz 2.5 flowmaster dual exaust apexi s-afc II K&N FIPK
#1156789 01/18/05 07:21 PM
mi5pal Offline OP
I ran some Berryman's B-12 in through the intake, had the injectors & throttle body cleaned for $50 at my local auto shop, and changed my oil this weekend. The car is running much smoother now, thanks for the advice everybody.
#1156790 01/23/05 03:37 AM
where do you get Berryman's in Canada?
#1156791 01/25/05 05:00 AM
What hose size will I need to fit through the vacuum line on the top of the intake manifold and how do you take the hose off. They seem to be glued on (not literally).
1996 Ford Contour GL 108,000 miles Automatic 2.5L Duratec V6 Engine
