#89370 04/20/02 03:31 PM
E
E
want to get new subs just want to know what is the different in a svc an a dvc.which one perfornce better out of the two.
99 Contour
JOSE
AIM:elflaco1981
#89371 04/20/02 03:38 PM
A DVC sub just gives you more wiring options which will help draw the most power out of your amp.
What amp are you using and how many subs will you be using?
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
#89372 04/20/02 03:53 PM
E
E
i might go with audiobahn and i would be using three of them hopefully two facing up and one facing down.i was told that make it feel like the ground is shaking when u drive bye.but i;m not sure about it.so dvc is better to get more power right. smile
99 Contour
JOSE
AIM:elflaco1981
#89373 04/20/02 04:03 PM
It all depends on the amp and what load it is stable into.
1999 SVT #900/2760
Born on 1-20-99
#89374 04/20/02 04:05 PM
I got DVC and it worked for my old amp but now i am getting about half that power to the subs from my new amp frown Went from 180 to 90w a sub. Still sound ok but not as good as before.
http://www.rockfordfosgate.com/rftech/wiringwizard/index.asp
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
#89375 04/20/02 05:03 PM
9
9
SVT colin is correct. It all depends on your setup, especially your amp. To start simple, lets say you have one 10" svc sub. Your amp is a 200w mono bass amp, and is stable at 2 ohms. Because the sub is svc, it will be running at 4 ohms(assuming the sub is a 4 ohm sub) and receiving 200w from the amp. Now, if the 10"sub was a dvc sub, you could wire the the system to run at 2 ohms, which is less impedence, meaning that each coil of the sub would get 200w,and there are 2 coils. So in theory, the dvc sub would be getting 2x the power(400w) than the svc sub(200w) using the same amplifier. The sound quality won't be quite as good at 2 ohms, but it really doesn't seem to matter with a subwoofer, because you can't really tell the difference. Now things can get really messy if you are running 3 DVC subs, especially depending on your amp smile The other thing you have to take into consideration is the work load of the amp. The amp will work harder under 2 ohms then it will at 4 ohms. For some amps this is fine, for others it can cause problems, like over heating, shuting off, damamge, and what not. Most mono amps and other amps designed to power subwoofers will be stable at 2 ohms, but you must check before you buy. Another good idea is to mount the amp in a spot in your car that has good circulation, buy an amp with a fan built in it, or rig up a fan or two to cool your amp. Good luck! smile
99 Tropic green svt
Custom Stereo
borla cat-back
22mm bat rear sway bar
custom K&N & heatshield
215/40/ZR17 Rubber
jimmkreider@yahoo.com
#89376 04/20/02 08:01 PM
Here's an example using three DVC subs.
Let's say you buy three DVC subs. Each VC on the subs are 3ohms.
You'll then wire the two VCs on each sub in series producing a total load of 6ohms for each sub.
Next, you'll wire the subs in parallel to the amp in parallel for a total ohm load of:
1/R = 1/6 + 1/6 + 1/6
R = 2ohms
Finally, find an amp that is stable into a 2ohm mono load. You'll probably want a very powerful mono sub amp.
1999 SVT #900/2760
Born on 1-20-99
#89377 04/20/02 08:05 PM
Here's an example of using three SVC subs. Generally, SVC subs are 4ohms.
You'd wire the subs in parallel to the amp for a total load of:
1/R = 1/4 + 1/4 + 1/4
R = 1.33ohms
You'll then need to find an amp which is stable into a 1.33ohm mono load (round down to 1ohm to make sure it's stable). You'll more likely spend more money for a 1ohm stable amp, have less of a selection, and might possibly have more heat dissipation/distortion problems to deal with.
1999 SVT #900/2760
Born on 1-20-99
#89378 04/21/02 02:00 AM
2
2
bkent has the Audiobahn 2200HC amp powering 2 Audiobahn Dual 4 ohm 12s at 1 ohm. The amp is 1 ohm stable and 1600W. Cost him about $350 shipped IIRC. Very loud.
2000 SE Sport V6
Deep Navy CC Metallic
My 2G Sport
#89379 04/21/02 03:00 AM
I
I
I have a new a.d.s. 8 channel x 50 @ 4 ohms. If I am bi-amping my front a.d.s. 345's, running coaxial in the rear, would DVC be a good choice for the sub? One sub or two? Box or freeair. Thanks
PS any sugestions on placement of amp.
2000 Contour Black V6 SE ATX Moon traction control ABS
still all stock but not much longer:-)
Eclipse 55430 HU
Eclipse DSP 2301
a/d/s P850 amplifier
a/d/s 345is components front
a/d/s A4im rear deck
shopping for a sub.
1995 Contour Midnight Blue SE V6 ATX, 160,000 Miles and still strong as ever, Leather(soon to be switched to my 2000),traction control.
" so roll down the windows and let the wind blow back your hair.
The night's busted open, these two lanes will take us anywhere..."
Moderated by  dnewma04_dup1
