Posts: 207 |
I searched, came up with nothing..
I'm trying to reduce rattle in my trunk and wanted to put some foam between my rear deck and the metal.. The only problem is, I don't know how to take the rear deck out. I have a 99 SE with no third brake light.
I'm not even sure if it's possible to remove it. I'm pretty sure it is though. So, if you can tell me how.. That'd be great. TIA
Posts: 1,356 |
If you fold down the seats, you'll see some push pins. If you pry them out partially and then pull them out with pliers. You'll know what I mean when you see them.
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
Posts: 207 |
My seats dont fold down =(
Will the pins still be there and be accessible?
Posts: 2,489 |
i did a how to for this in the audio section i think.
anyways, pop up the bench seat. youll see 2 torx screws, one on each side attaching to the back of the seat. t45 or t50. take them out, then pull the seatback up and out. kinda tricky, you need a friend to help. there is a plastic/metal clip in the trunk that attaches to the seat and needs to be manuvered around. take a look at the whole thing and you will see. anyways, then pop out the plastic screws attaching to the rear deck and it will slide out. does not matter if you have fold down seats.
kind of a fast write up, but there ya go. any questions just ask.
1998 T-Red CSVT 3.0L
Posts: 3,335 |
Make sure you disconnect the wiring for the third brake lamp before you pull too hard.
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 3,345 |
Originally posted by ExDelayed: Make sure you disconnect the wiring for the third brake lamp before you pull too hard.
Originally posted by foldthecorners: I have a 99 SE with no third brake light.
1996 MM
Zetec, ATX
192000 kms...not dead, but I'm not fixing it
White people love Wayne Brady because he makes Bryant Gumbel look like Malcolm X.
Posts: 6,910 |
its also easier if you remove the bolsters at the sides of the rear seat, not sure if that is the same if you don't have folding seats but it looks like it
- 95 Mystique LS - Zetec/5spd
Posts: 3,335 |
Originally posted by Bullet:
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 2,446 |
the bolsters are seperate on the folding seat only, not on a fixed back seat. found that out when i converted to folding
