#1156161 01/13/05 11:48 PM
Can anyone help me I'm new to certain things like gauges I have a Chiltons for my tour and it only tells me where the oil pressure sender is for the 2.0 and mines 2.5 but i need to know where it or any other spot is to hook up my oil pressure sender for the new Gauge any HELP wold be highly appreciated
#1156162 01/14/05 12:07 AM
"The [oil pressure sending] switch is screwed into the rear of the cylinder block, adjacent to the oil filter." Haynes Repair Manual, Ford Contour and Mercury Mystique 1995 - 2000, p 2B-19, section 17.
I just copied the above quote from my mighty Haynes manual; I have no personal experience with the V6.
#1156163 01/14/05 02:21 AM
I'm pretty sure you will need a different sending unit... your guage will not work with the current sending unit since all it does right now is get to a certain low pressure and then make the light illuminate... on your guage you'd see either nothing or full swing all the time, unless the oil light was on, then it would be the opposite.
Mine was done by previous owner, but they used a hole that you have to uncover below and to the right of the throttle body and use a pipe fitting, then put the new sending unit in that.
Maybe searching around would help?
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
