I will put the shield back on. Most of the job was getting the 6 bolts out of the shield. I can imaging getting them back in.
I changed the rack without dropping the subframe, and with everything in place. Quite a job. I dropped the rear of the subframe only about 2". Pulled the coil off the rear cam cover to snake an extention down to the bolts. Everything else,(tie rod ends, steering coupler, P/S lines),was pretty simple. I stripped one subframe mounting bolt, and had to torch a hole in the body to cut the nut off.
