#89307 04/18/02 04:16 PM
TrUjAp Offline OP
Here's a question for you car audio fanatics:
What is your opion about high voltage pre outs on a deck??? People say that the higher voltage pre out helps alot, but then other people say that it's just mumbo jumbo!!!
So what do you guys say about this???
1997 T-Red Contour
V-6 MTX
Magnaflow custom dual exhuast
SC Cold Air induction
Sony LCD screen with PS 1
Neon interior lights,gauges
Momo shifter knob
SVT E0 Rims
Touring Spoiler
In the means to change the sound system.
#89308 04/18/02 05:28 PM
E
Eli Offline
E
i've heard high voltage outputs are very helpful too - i know you need to adjust to amp's levels according to the voltage of the signal.. but i dont know why. im just as interested in knowing the answer as you are, so i guess this is just an extended
BUMP
96 Contour SE, MTX
2 Pioneer 12"s in a bandpass box
2 5x7 Pioneer Plates
2 Stock Speakers
600 watts of blistering radioshack power
#89309 04/18/02 05:51 PM
higher voltage pre-outs are better in complex systems...in a simple h.u. 1 amp setup, you might not notice the difference, but with multiple lines running, they do offer better signal transfer, and they are much easier for your amp to deal with...To try to paint a picture of this, imagine a slope from low to high...with, say a 1.8V output, your slope is very steep, the amp not having much room between zero power and full power...with a 4 or 5V. output, the slope is much more gentle...Keeps your amps cooler and with you longer....
HTH
Ride: 2000 T-red SE
Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE
Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
#89310 04/18/02 06:16 PM
Hi-volt pre-outs are primarily for eliminating noise from the system with a "stronger" signal with less noise making it to the amp (higher S/N ratio).
I don't believe it has any effect on the amp's life or its heat dissipation. Those are traits inherent to the amp. It'll amplify noise just as well as it will amplify the signal. It doesn't know the difference.
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
#89311 04/18/02 06:51 PM
I agree that they eliminate noise (see previous post), but they also give more headroom...thus the gain settings...setting the amp's gain at 1.8V with a 5V pre-out would waste most of the amp's available power...
KnuKoncepts explained this very well in a thread a couple weeks ago...pretty much the amp will be running at full power when the input voltage and gain settings match...if they are different, your amp is gonna be off kilter..(Gawd, I love the phrase "off-kilter") :p
Ride: 2000 T-red SE
#89312 04/19/02 01:31 AM
It depends greatly on the amp that you are using. 4v outputs with an amp with only a 2v max input would be automatically driving the amp into clipping. That is why line drivers are virtually useless unless you have an amp with a very high input voltage.
#89313 04/19/02 01:54 AM
KnuKoncepts explained this very well in a thread a couple weeks ago...pretty much the amp will be running at full power when the input voltage and gain settings match...if they are different, your amp is gonna be off kilter..(Gawd, I love the phrase "off-kilter") :p [/QB]
Actually, you've got it reversed.
As long as the HU can produce at least the minimum input of the amp, the amp will be able to produce its maximum output.
For example, let's say your HU only puts out 2V and your amp's input range is 1-4V. Therefore, you set the gain on your amp to 2V and your amp will produce its full potential.
If you set your amp's gain to 1V, like Dave said, you'd be driving it into clipping and risk damaging your equipment.
The gain setting on the amp is ONLY to match the voltage between the HU and the amp. I believe you're referring to the post where Knu was explaining how to set the gains by ear without knowing the actual voltages.
So there! :p wink
1999 SVT #900/2760
Born on 1-20-99
#89314 04/19/02 05:00 PM
H
H
The higher the output V on a HU( w/an amp with equal or greater input V ) can yield a more precise and sensitive adjustment - but yeah your only trying to match the two in the long run ( since all or most amps/HUs are different ), higher Vs just give you more headroom to work with.
My question is why hasn't anybody ( company ) made a set of balanced outputs/inputs for hardware?! Is that what alpine has done? I have a ALP 4V HU to ALP V12 amp that is switchable nom/4V but is the HU always pumping out 4Vs?..anyway they should just make everything digital coaxial RCA so theres no "levels/clipping" to worry about~ yah know!
#89315 04/19/02 07:07 PM
you caught me being wrong on that one...Thanks for not bi+ch-slapping me into last week for it! laugh
Ride: 2000 T-red SE
#89316 04/19/02 08:26 PM
No worries. I figured it was just a typo or something. wink
1999 SVT #900/2760
Born on 1-20-99
Moderated by  dnewma04_dup1
