#1153408 01/12/05 10:32 PM
JAWSVT Offline OP
I have a code reading p0401 which is insufficiate EGR flow. I had all 3 EGR pieces replaced, and CEL is still on with that code. What can I do now?
#1153409 01/12/05 10:45 PM
Welcome to CEG!
What three pieces? The EGR valve, DPFE, and EVR???
Most common problem is carbon clogging the passages in the intake from the EGR valve to the throttle body. Remove the throttle body and dig them out.
#1153410 01/12/05 10:54 PM
first clean the passages near the tb then check out the DPFE sensor
when I had a P0402, exsessive egr flow at idle it was the dpfe
#1153411 01/19/05 12:02 AM
I had the same code before I did my UIM/LIM rebuild. The EGR passages were clogged/filled with oil/carbon where the TB meets the UIM. I am still waiting on parts from the dealer to finish mine, but take the TB off and clean the passage and back side of the TB, as it will be probably look nasty. If the passages were as clogged as mine were, the rest of your UIM/LIM probably looks the same, especially the LIM.
John 95 Contour 99 F150 85 RX7
#1153412 01/19/05 01:49 AM
Try this... clicky
