#1151845 01/11/05 01:26 AM
ty_888 Offline OP
I have the SVT for 4 months. I changed the front pad, battery, plugs and wire. IMRC module replaced. TB Cleaned and replaced PCV. In general, the car runs well.
Last month, I have the CEL code P0402 (bank1 pre-cat). Cleared the code and the car is running good, no hestitation, no loss of power.
Last week, CEL code P0302, cleared the code, (miss fire Cyl#2)the car idles fine, no hestitation. I took it to 6k rpm and runs well. I do not get any sign of misfiring at all.
I really don't why the CEL so sensitive. CEL lights up when the car is running fine. Is it possible the gasoline. Normally I fill up with Esso 91. But I find fill up with c-tire 91 gas, the car runs better. Any suggestion on which gas company is the SVT's choice.
Since the code never come back, is it okay to ignore it till spring, I wait until warmer weather then check out the plug and and gas filter.
How can I check if the coil pack problem, may be the snow/water ended up on top of the coil pack.
98 SVT BLACK 98 MYSTIQUE ZETEC 04 RX8 GT MT6 TITANIUM
#1151846 01/11/05 02:03 AM
I am Canuckian
I am Canuckian
Well personally I feel that if it is not a recurring code that you need not pursue it yet. In other words you may not have to do anything till it comes back again. How are you getting your codes read though? If you are paying the dealership to read them then you may want to solve the problem at hand before you spend more money on reading the codes vs repairing the reason you are getting them in the first place.
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
#1151847 01/11/05 01:58 PM
ty_888 Offline OP
Got a cheapo odbii code reader from ebay, only read & reset the code.
What kind of sign of engine misfire?
Moderated by  Gerald_dup1, mbb41_dup1
