Dex-Cool also has the problem of not mixing with the normal antifreezes. You must be **completely** sure that there is no regular antifreeze left in the system before you fill with Dex-Cool.
Personally, I am running
Zerex G-05 antifreeze. Main reasons?
Approved by Ford and DaimlerChrysler for use in automotive and diesel engines.
Utilizes hybrid organic acid technology to minimize inhibitor depletion
Low-silicate, low-pH and phosphate-free formula
The only drawback is it is very pale yellow. Its a PITA to see in the resivour. From what I have found around here, it can be found at pretty much any chain auto parts store.
The only better one on the market (while still staying with antifreeze) is Zerex G-48 (IIRC), and it can only be found at the BMW dealer.
You could also bring up the topic of Evans Waterless Coolants, which is something I will probably look into for the truck.
So... back to topic.
