Can you tell I'm interested in this car. There was some "SVT is not dead" article where someone from Ford said the the Fusion is under consideration for SVT treatment. Other sources have said that this would put it above the ST designation that will be due out with the Duratec35. I guess I'll just have to "suffer" with my SVT for another few years.
George Hodge
New: Volvo S60R
Old:2000 SVT Silver Frost 1188/2150
DMD, 75mm Pro-M, HPP rear strut tower bar
Aussie 24mm sway bar (with boxed in subframe)
BAT European Handling Kit, Brullen Y-pipe
Performance Ford spherical bearing end links
that is the contour replacement. Im definately going to be looking into one in the future.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Quote: Engineers also pumped up the brakes, stiffened the structure and tuned the Fusion for softer ride and handling than the Mazda6.
Why numb up a car - WHY WHY WHY!
Quote: A 3.5-liter V-6 under development at Ford also could find its way into the Fusion. An all-wheel-drive option will be added after the launch, likely in the second year.
