Just installed a 95 2.5 in a 96. When i try and start it there is no spark. The engine ran when it was in the 95. I changed all sensors and the top of the intake from the 96 engine on to the 95 engine. I never heard the 96 run. The timing chain was broken when i bought the car and the top half of the motor was in the trunk. What controls the spark? Cam sensor? Crank sensor? All fuses are good. Fuel pump is working when i crank it. CEL is on when cranking. I scanned it and the only code that comes up is oxygen sensor heater out of range.
CRASSELL
95 Contour V6 auto
96 Contour V6 5 spd
97 Contour 2.0 Auto
Found the problem. One of the 3 large wire loom plugs on the right rear side of the engine, was not plugged in all the way. Anyone need any Contour parts, i'm parting out the old car. Check my add on the classified page.
CRASSELL
95 Contour V6 auto
96 Contour V6 5 spd
97 Contour 2.0 Auto
