#1146282 01/04/05 08:37 PM
My power steering is leaking out of the fitting on top of the pump. Is there a seal that I can replace or do I have to get a new pipe and fittings?
Chris Carr92 SHO MTX~99 Taurus SE~95 Contour SE "Be good. If you cant be good, be careful. If you cant be careful, name it after me. Anonymous"
#1146283 01/05/05 12:47 AM
There is a teflon gasket that goes on the fitting. Dealer has them. They are very cheap maybe .50 to 1.00.
#1146284 01/05/05 01:55 AM
N
N
Yes the gasket that sewerman talk about is probably the problem. Check, when you will unconnect the hose to be sure that the fitting and the hose are in good shape.
P.S. You will need to extend the teflon ring when you will install the new one, it's a tight fit and it's normal.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
#1146285 01/05/05 11:47 PM
Great, I will have to go there soon to get that. It is only getting worst. I found that someone has tried to fix it already. I asked the guy I got it from and he said it was just some shop, not a dealer.
#1146286 01/10/05 05:30 PM
Terry had a great fix for this, teflon thread tape. It worked like a champ as far as I can tell.
#1146287 01/11/05 03:55 PM
Well I think that might of been part of the problem. Now it is leaking down the side of the block. I might see if I can take a look at it today if I have time.
