#1145883 01/04/05 05:10 AM
When I start my car, and when it idles, I get a steady "ticking sound". It is very evenlly spaced, about 1/2 to 3/4 second between ticks. It mostly does it on idle when the car is sitting, with my foot on the brake, and in drive. It sounds kinda like "chhh, chhh, chhh, etc.". I am thinking I might need to replace my serpintine belt. I am also doing an ATX fluid change for sure. Any suggestions?
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
#1145884 01/04/05 12:03 PM
check the timing belt
1999 Ford Contour SE Zetec with 137k miles. AIM Name: ContourAlf Yahoo IM: Contour_Freak
#1145885 01/05/05 05:38 AM
Any other ideas? Any easy way to do this on a Zetec?
#1145886 01/05/05 06:00 AM
May be an exhaust leak.
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
#1145887 01/05/05 06:10 AM
Sure it's just not normal ticking sound?
#1145888 01/05/05 06:37 AM
The only "normal" ticking sound i here is when the engine is off after it is hot. Sometimes I here the current sound while in traffic, sometimes I don't, so I don't think it is normal.
#1145889 01/05/05 06:48 AM
I forgot about the "normal" ticking sound. Mine has had it since I bought it. I was assuming you heard a sound other than the regular one
#1145890 01/05/05 12:23 PM
Id say pull the top cover off the timing belt and see if it goes away. If it does your timing belt is prety streched out.
#1145891 01/05/05 02:34 PM
I am thinking it could be dirty fuel injectors. I had a simmilar type problem on my '99 SE. Sounded almost like I had sucked a valve. IIRC, it didn't get any louder as I gave it moe gas. Could be wrong though because it was a while back.
Pured a bottle of the Chevron with Techron injector cleaner, and a tank later the ticking had subsided. There was always a faint ticking sound though. Guess that is the normal tick. Can't be bad I guess because I have 206,000 miles on the car now.
99 SE V6 Silver Frost 201,592 Miles (Still Running Well)
#1145892 01/05/05 02:57 PM
Could be your valves or lifting arms sticking. I had this problem on my 66 mustang and I had to manually replace one of the lifter arms. Chemicals will only cover it up.
E0 #4384 of 6535 Born Jan. 9 1998 My SVT from the ashes 147,466 miles, purchased Nov. 2002 @ 76,559 miles
