#1145431 01/03/05 11:01 PM
CAMLRDR Offline OP
ok well i havent taken a look at the handle yet but long story short since my key got lost at the shop i got my rear passenger handle with the front one switched so the only keyholes i have left are the trunk and drivers side..well today i got my alarm installed so i want to install the rear drivers side handle in the front also ..i already had the shop paint the handle the same color as the car so i can swap them wen i get the alarm..*i have shaved rear handles if ur wondering* so does anyone know how to remove the handle and hookup the new one?? or like a picture or anything..thanks in advance..
NEW RIDE: 93 NON TURBO SUPRA Black/Blue pearl 97 V6 GL Duratech 5%tint around survivor kit 2 10" 450w pioneer subs and tv kenwood 3way 300w speakers air ride 18's intake my cardomain
#1145432 01/03/05 11:18 PM
CEG road warrior
CEG road warrior
Pop the cover off the handle and use a Phillips head screwdriver to pull out the screws.
#1145433 01/03/05 11:55 PM
CAMLRDR Offline OP
ok thanks il take alook at it when i get my car back tonite..
#1145434 01/04/05 02:48 AM
You are talking about the OUTSIDE handle, so that there is no keyhole, correct?
Wouldn't you remove the door panel on the inside, and then undo the outer beveled surround from within the door? May require removal of the actual handle mechanism, too, then re-install..
Ray
#1145435 01/04/05 09:06 PM
CAMLRDR Offline OP
ok i got it i removed the door panel then the 2 bolts and the trim came off of the handle fromthe outside but one part wasnt comign on so i snapped it off since ihad the extra painted handle and i got everythign to fit nicely but the siver rod that is attached to the handle and opens the door will not fit becuase of the angle at which u have to turn and twist it to get it on but i managed to get it on and working...well if it comes off while im not at my car ill be climbing in threw the passenger door.
