Posts: 1,444 |
so i got the crutchfield amp bypass kit and the metra kit to put the oem tape player back in the 95 gl. This shouldn't be a problem. i'm putting the jensen hu from the 95 into the svt.
do u guys have any tips or things i should look out for? i have the intructions from crutchfield. is it basically following them. the bypass harness has a ton of wiring. will i need it all. can i snip some of it off? i'm doing this tomorrow (saturday).
if going to be putting in the dash clock while i'm messing w/ the wiring and radio.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 2,848 |
they must give you a mile of wire...no you probably only need 3 feet of it and that's being generous. The excess does come in handy for other do it yourself projects though.
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 15 |
How much WAS THAT AMP By-Pass kit for your contour.
Big Pimpin' 96 Contour SE. 2.5L V-6, 24VL DOHC, 5-speed Phat System pushing 2 12" JL Audio W0 Pushing around 175hp right now at crank purple neons under dash APC fog lights with hyper white bulbs Hyper white headlight bulbs K&N air filter
Posts: 1,032 |
I paid $20 + $4.95 for S/H when I ordered it a while back. It included all of the necessary wiring harnesses for installing your stereo, the amp bypass harness, radio removal tools, and detailed instructions for everything stereo related (HU, amp bypass, antenna replacement, speaker replacement front/rear).
1999 SVT #900/2760 Born on 1-20-99 Silver Frost/Midnight Blue A few aesthetic and audio mods
Posts: 1,444 |
mine was about 22 w/ shipping. i didn't need the hu removal tool (already had one)
AIM:omegazodiac
