Page 2 of 2 1 2
Good Info Mikey Boy...Its Probably Archived Around Here Somewhere But, Alas, I Am Lazy....Hope All The Info Helped out Mobius....Good Luck On The Install........
CSVT E0 3L 14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
This is also what Terry told me, however it doesn't make sense as apparently numerous people have swapped the ring gear without having to swap the output shaft as well.
As well, I do not get the gear stepping problem 100% of the time, only some of the time. Other times everything will spin like butter like it should, sometimes it won't. It's totally hit or miss.
Damn it this is pissing me off. As soon as it stops raining I'll probably take it apart, a FORTH time.
-mobiuslogic
9
I should have known that. I remember reading that on here somewhere. I am glad you got the problem figured out, now you just need to get it fixed.
1999 Cougar V6 MTX SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
our parts list here is not updated nor accurate so it really causes more problems then it solves. just a heads up.
Oo (xxx)oO o xxxxxxxx o
Originally posted by 99cougar:
Duratec=4.06
Zetec=3.84
Thanks. I wasnt sure if I was correct.
-tropictour
2000 Contour SVT Tropic Green SHO Shop CAI Bassani 1999 Contour SE BAT Kit
Page 2 of 2 1 2
