#1139915 12/25/04 11:47 PM
im looking for some nice street tires does anyone have any good ones i should look at and if you know the price that would be great
#1139916 12/26/04 05:29 AM
How about you say for what wheel size and what you want outta the tires. We're not psychics.
#1139917 12/29/04 12:17 AM
185 60 r 14 i want good tires for road rallys
#1139918 12/29/04 06:34 PM
You might want to go with a wider tread patch; 195-60/14 are what I had on my car.
I presume you use your car as a daily driver too. Go with a good touring tire. Hit tirerack.com and check out the Yokohama AVID TOURING tire. Was a fantastic tire for me & my daughter. Only better tire I could find with the desired characteristics was the Bridgestone Turanza LST - which I just replaced on my car. The Yoks were smoother & quieter, but man the Bridgestone never gave up, always gripped when I needed them most.
Both of those are 70,000 or 80,000 mile tires - excellent value & good all around performance.
#1139919 12/30/04 12:46 AM
BF goodrich Radial T/A 215/60/14...wont be regretted
2002 Cougar 2.5 duratec/ mtx-75 85,0000 Mondeo ST-200 wheels/BFG KDW NT black/black Spec Stage 1 Torsen T-2 Trubendz 2.5 flowmaster dual exaust apexi s-afc II K&N FIPK
#1139920 12/30/04 03:09 AM
That tire is way too large. Speedo will be off big-time. Better if you take the profile down a bit.
205/55-14 should be just about spot-on!
#1139921 12/30/04 06:16 AM
Actually 215/60/14 is almost dead on match for speedo. I don't know if that wide of a tire will fit the stock wheels though.
#1139922 01/01/05 09:41 AM
im looking at some nakang EX-601's there 185 60 R 14 82H what does the 82H mean
#1139923 01/02/05 04:53 AM
JB1 Offline
82 is the load rating and h is the speed rating, see here:
Service Description
The service description consists of two things:
Load Ratings: The load rating is a number that correlates to the maximum rated load for that tire. A higher number indicates that the tire has a higher load capacity. The rating "105," for example, corresponds to a load capacity of 2039 pounds (924.87 kg). A separate note on the tire indicates the load rating at a given inflation pressure.
Speed Rating: The letter that follows the load rating indicates the maximum speed allowable for this tire (as long as the weight is at or below the rated load). For instance, S indicates that the tire can handle speeds up to 112 mph (180.246 kph). See the chart on this page for all the ratings.
site full of details about those pesky numbers on our tires
00 black/tan svt, #2052 of 2150, born 2/1/00 formerly known as my csvt "Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
#1139924 01/02/05 05:27 AM
well those tires are mounted on my car right now? i think they ride pretty nice, they definetely dont rub or anything and they definetely give me the traction i need throughout mother natures little escapades
Moderated by  1314_dup1
