#88498 03/28/02 09:48 PM
I'm ordering some 9709T19
Adhesive-Back Damping Sheet Polymeric from http://www.mcmaster.com My question is how many sheets does it take to do all 4 doors and the entire trunk. I'm thinking 4 maybe 5. I just put the bandpass in last night and it rattels the trunk like a mofo.
91 Honda CRX
Bilstein shocks, Tenzo R springs
96 Ford Contour LX V6 ATX
KKM intake, Ford Motorsport 9mm wires
All Kenwod Stereo System - 134db
KDC-8016 headunit, KAC-859 amp, KSC-BP210 bandpass, DualMags: 6.5" front and 5.5" rear
#88499 03/28/02 10:17 PM
Depends on how well you want the doors covered. I did the inside of the door and then covered the inner door skin with one large peice of dynamat, cutting out only the speaker and door lock peice. Thats roughly 1.5 sheets a door for the front. Never bothered with the trunk yet.
#88500 03/31/02 08:52 AM
I'd order more than you actually expect you need. How big are the sheets? for all 4 doors, i used a total of 20sq feet on all 4 of my doors. It might be a little much, but it was worth it. I actually only had 10sq feet, but i ended up buying more because i liked the effect it had. So you should consider buying more. Hope this helps
Give me more beer and CEG before i get depressed!
AIM/AOL: DBZ Jr
Moderated by  dnewma04_dup1
