Posts: 58 |
I read in an other post that someone had a low and rough idel and then changed the catalytic converter and it went away so I have the some problem and I have tried everything else but every place I go they want to charge $200 or above and it is a universal cat. Is it this much or is someone tring to take me for a ride?
Posts: 2,725 |
$200 is about right, I wouldnt be replacing it unless I had a code for it. Have your done everything else to try to fix your rough idle.
Injectors that are dirty an cause it, IAC valve yeah that can to, vacuum leak also would, probaly a lot more to.
Posts: 58 |
I mean everything clean the Maf,change IAC valve ,the egr,spark plug and cables and more It runs great except it hesate on acceloration and the idel is very low and rough and no check engine light.
Posts: 839 |
Originally posted by HITMANinMI: $200 is about right, I wouldnt be replacing it unless I had a code for it. Have your done everything else to try to fix your rough idle.
But.. the main catalytic converter doesn't give a code.
$200 is a little high (but not out of the park), pick yourself up one from CTA motorsports for like $60 and just get it welded on.. shouldn't be too much.
The Spickle
New Car: Infra Red '04 FSVT
Former Car: Black '98 CSVT, #3137/6535 "The Unluckiest car.. ever"
Posts: 205 |
CTA Motorsports has universal cats for $79 up to 2.5" ID, I would go with one of those and eliminate the stock one (which is why you posted this of course), that way you can eventually get an exhaust header without too many issues...
92 Talon TSi AWD
DSM= Daily Scheduled Maintenence
Posts: 21,653 |
Originally posted by SpliceVW: Originally posted by HITMANinMI: $200 is about right, I wouldnt be replacing it unless I had a code for it. Have your done everything else to try to fix your rough idle.
There is only one cat and yes it can give a code.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,483 |
Get a high flow Cat is your going to replace it.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 205 |
Originally posted by SleeperZ: Get a high flow Cat is your going to replace it.
The CTA converters are high flow:
"Car Sound (Magnaflow) High Flow Universal Catalytic Converters High Flow Universal Converters flow so efficiently, motorsport's enthusiasts can enjoy better performance and do their share for cleaner air. Replaces main catalytic converter. Meets all CARB requirements. Available for all makes and models. Other converters also available."
92 Talon TSi AWD
Posts: 750 |
Originally posted by golgo13: I read in an other post that someone had a low and rough idel and then changed the catalytic converter and it went away so I have the some problem and I have tried everything else but every place I go they want to charge $200 or above and it is a universal cat. Is it this much or is someone tring to take me for a ride?
What year Zetec do you have ? I wasn't able to find a cat cheaper than the $600 ford one for my '97...
Tiv
Posts: 58 |
It's a 95 and the universal was what I a price for it is not the fitted. I an going to try the CTA cat they make go stuff.
