#1137334 12/22/04 12:41 PM
golgo13 Offline OP
I read in an other post that someone had a low and rough idel and then changed the catalytic converter and it went
away so I have the some problem and I have tried everything
else but every place I go they want to charge $200 or above and it is a universal cat. Is it this much or is someone tring to take me for a ride?
#1137335 12/22/04 01:24 PM
H
H
$200 is about right, I wouldnt be replacing it unless I had a code for it. Have your done everything else to try to fix your rough idle.
Injectors that are dirty an cause it, IAC valve yeah that can to, vacuum leak also would, probaly a lot more to.
#1137336 12/22/04 03:38 PM
golgo13 Offline OP
I mean everything clean the Maf,change IAC valve ,the egr,spark plug and cables and more It runs great except it hesate on acceloration and the idel is very low and rough and no check engine light.
#1137337 12/22/04 03:45 PM
But.. the main catalytic converter doesn't give a code.
$200 is a little high (but not out of the park), pick yourself up one from CTA motorsports for like $60 and just get it welded on.. shouldn't be too much.
The Spickle New Car: Infra Red '04 FSVT Former Car: Black '98 CSVT, #3137/6535 "The Unluckiest car.. ever"
#1137338 12/22/04 06:39 PM
CTA Motorsports has universal cats for $79 up to 2.5" ID, I would go with one of those and eliminate the stock one (which is why you posted this of course), that way you can eventually get an exhaust header without too many issues...
92 Talon TSi AWD DSM= Daily Scheduled Maintenence
#1137339 12/22/04 07:47 PM
There is only one cat and yes it can give a code.
#1137340 12/22/04 09:03 PM
Get a high flow Cat is your going to replace it.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
#1137341 12/23/04 12:12 AM
The CTA converters are high flow:
"Car Sound (Magnaflow) High Flow Universal Catalytic Converters
High Flow Universal Converters flow so efficiently, motorsport's enthusiasts can enjoy better performance and do their share for cleaner air. Replaces main catalytic converter.
Meets all CARB requirements. Available for all makes and models. Other converters also available."
#1137342 12/23/04 09:26 AM
What year Zetec do you have ? I wasn't able to find a cat cheaper than the $600 ford one for my '97...
Tiv
#1137343 12/23/04 12:20 PM
golgo13 Offline OP
It's a 95 and the universal was what I a price for it is not the fitted. I an going to try the CTA cat they make go stuff.
